Brightest LED smart bulbs 2025: The best lights for dark spaces
Quick Menu
Smart LED lights have changed the way we light our homes with fine controls and millions of colors, but some smart bulbs aren't always bright enough for a big space. Luckily, bright LED smart lights do exist with dimming so you can find the perfect setting for your room. You can even get bright bulbs with full color so you can tune your lighting to the mood. These bulbs are more power effiecient than halogen or fluorescent bulbs so you can save power too.
So whether you want a standard A19-E26 bulb or the BR30 for recessed lighting, there's a bulb for you. The Feit Electric OM100 is our top pick for its incredibly high lumen rating and hub-less smart controls, which means it only needs Wi-Fi and your phone to control. There are more options too depending on what features and price you're looking for.
Samuel Conteras
Samuel Contreras
Sam has been an Android fan since first trying out the HTC Evo 4G at a Sprint store. As a phone technician, he became familiar with what matters most to those picking a new phone and accessories and has been writing about carriers and plans at Android Central since 2019.
At a glance
Best overall
Feit Electronics 100W equivalent bulb
(Image credit: Feit Electronics)
1. Feit Electric OM100 - RGBW
Best overall
Specifications
Brightness: 1600lm
Hub required: None
Color: RGBW
Reasons to buy
High 1600LM rating
No hub required
Google Assistant and Alexa integration
Reasons to avoid
The app can be finicky
Brightest setting only applies to the white color tone
Limited preset scenes in the app
While Feit Electric may not be a well-known smart bulb, it's been innovating and creating high-quality lighting solutions since 1978 — and the OM100 RGBW bulb continues that trend. Since this bulb doesn't require extra hardware such as a hub, this Wi-Fi-enabled smart LED bulb is simple to set up.
It has a peak output of 1,600 lumens, making it the brightest LED smart bulb on the list, equal to a traditional 100W incandescent bulb — that's some serious light. You'll get a tunable white, with a color temperature range from 2700K soft white to 6500K daylight, and millions of RGB colors.
Feit Electric not only created an ultra-bright LED bulb here, but it also made it so that integration with Alexa, SmartThings, and Google Assistant is a snap. The inclusion of 2.4GHz Wi-Fi means all you need is to connect it to your Wi-Fi, and you're up and running. Feit Electric also has an app compatible with iOS and Android, so you have that option if you don't have a smart speaker or prefer not to use voice commands.
Within the app, you can set the brightness of your bulb(s) and tune the colors. There are also some scenes and schedules that you can configure to automate your lighting. This bulb's connectivity features allow you to take full advantage of its very high brightness to illuminate your darkest spaces best.
Best color bulb
Wiz smart LED light over a table
  (Image credit: Wiz)
2. WiZ 100W Eq. A21 Color LED Smart Bulb
Best color bulb
Specifications
Brightness: 1600lm
Hub required?: None
Color: RGBW
Reasons to buy
Bright 100W equivalent (1600 lumen)
Full-color bulb
Compatible with Google Assistant and Alexa
Easy setup with the Wiz app
Reasons to avoid
A21 size may be too large for some lamps
Some connectivity issues
Wiz is a smart home brand owned by Signify which also owns Philips Hue, so it knows a thing or two about smart lighting. You can set it up using the Wiz app and there's no hub required as the bulb supports both Bluetooth and Wi-Fi. Naturally, voice control is supported with Alexa, Google Assistant, and Siri Shortcuts. It also works with Samsung SmartThings and is Matter compatible so it should fit right in with just about any smart home setup.
This 100W equivalent full-color bulb is brighter than standard bulbs with 1600 lumens of brightness. You can set it anywhere between cool and warm temperatures for white light or set a customer color. If you have two of these bulbs in a room, it can even act as a motion sensor that automatically lights the room.
Keep in mind that this bulb is an A21 size meaning it's slightly bigger than a standard A19 bulb. If you have a shallow light fixture or a small lamp, this bulb may not fit properly. Even so, this bulb puts out a ton of light at a reasonable price with compatibility with just about any smart home system you can get.
Best spotlight
Ksuin smart bulbs
(Image credit: Khsuin)
3. KHSUIN 16W BR30 Smart Bulb
Best spotlight
Specifications
Brightness: 1600lm
Hub required?: None
Color: RGBW
Reasons to buy
Great price
Excellent brightness
Easy setup
Reasons to avoid
Weak color saturation
Falls off-network periodically
Limited app functionality
KHSUIN makes a very bright BR30 bulb at 1600LM, a 150W equivalent! With this level of brightness, you'll be able to make even the darkest room shine. One note to keep in mind is that you'll want to set it on the white color spectrum to obtain peak luminosity.
When not going to the ultra-brightness, you'll still have over 16 million colors to choose from. This ensures you'll be able to find the perfect shade to get the mood just right. While it does offer a full range of colors, saturation isn't very good at the higher brightness levels.
KHSUIN does include 2.4GHz Wi-Fi so you can connect to the Smart Life app for controlling colors and brightness and setting up some scheduling and scenes. You can also connect the bulb to your Alexa devices or Google Assistant-enabled speakers with app control. IFTTT is another service that will work with KHSUIN bulbs for more smart home automation, but you won't be able to use Apple HomeKit.
Amazing colors
Lifx smart bulbs patio
(Image credit: Lifx)
4. LIFX BR30 Wi-Fi Color Bulb
Amazing colors
Specifications
Brightness: 1100lm
Hub required?: None
Color: RGBW
Reasons to buy
Amazing color vibrancy
Easy to connect with existing smart home
No bridge or hub required
Extensive range of whites
Robust app
Reasons to avoid
Network connectivity can be inconsistent
The app can seem a bit cluttered
Pricey
While LIFX BR30 bulbs aren't the brightest LED smart bulbs around, these do have the most vibrant colors. Bulbs from LIFX can be interwoven with your smart home without adding additional hardware to control the light. Since the bulbs are Wi-Fi enabled, all you have to do is connect them to your network using the LIFX app and you're ready to go.
The LIFX app is robust and full of preset scenes, effects, schedules, and more. For further controls, these bulbs are also compatible with popular smart assistants like Alexa, Google Assistant, Apple HomeKit, and Samsung SmartThings. These integrations allow voice commands and create more customized actions by linking to other services within your smart home setup.
The bulb is designed for floodlighting across surfaces, which is why it works wonderfully in recessed lighting fixtures built into ceilings. They pump out white color temps from warm 2500K to super-cool 9000K with up to 1100LM, so these bulbs are bright. Aside from excellent brightness and a fantastic range of whites, LIFX is known for some of the best color saturation. They produce brilliant reds, blues, and greens that blend into millions of combinations, giving you just the right vibe.
Warm and bright
Sengled smart bulbs in kitchen
(Image credit: Sengled)
5. Sengled Zigbee Smart Bulb Extra Bright
Warm and bright
Specifications
Brightness: 1500lm
Hub required?: None
Color: Soft White
Reasons to buy
Fantastic brightness
Even color temperature
Multiple hub connectivity choices
Reasons to avoid
Only one color choice
Single color temperature
Needs hub for a lot of connectivity
Sengled gave this smart LED bulb the moniker Extra Bright for a good reason since it cranks out up to 1500LM of brightness. That number puts these bulbs at number two for overall brightness on this list. The biggest drawback of this bulb is the color, though — let me explain.
Sengled gave this bulb extra brightness but took away the ability to tune the color temperature. So instead, you are locked at 2700K, a softer and warmer light, which is fine in most situations. The upside is there is no question as to what setting the light needs to be to ensure you can take full advantage of the full 1500LM of brightness.
In terms of smart controls, you get all of the scenes and routines you can expect from a smart light when paired with the Sengled Smart Hub. You can set up the Sengled bulb with hubs from SmartThings, Wink, and Zigbee-enabled Amazon Echo devices. You can also use Alexa or Google Assistant voice controls, but a hub must connect to the bulb. So if you are good with a bulb that offers fantastic brightness in only a single color, then this is the bulb for you.
Best lighting kit
Philips Hue official lifestyle 2
(Image credit: Source: Philips Hue)
6. Philips Hue Smart Light Starter Kit (3 Bulbs)
Best lighting kit
Specifications
Brightness: 1100lm
Hub required?: Hue Bridge (included)
Color: Soft White
Reasons to buy
Includes a Bridge, Smart Button, and 3 Bulbs
Extensive smart features
Bright 1100lm bulbs
Bridge works with other Hue bulbs
Reasons to avoid
More expensive than other options
Philips is one of the most popular smart light brands, and for good reason. Its bulbs offer reliability, multiple form factors, and great connectivity. A Hue starter kit has everything you need to get connected and this bundle comes with a Bridge, a Smart Button, and three 1100lm bulbs.  These A19 bulbs will fit in most standard light sockets while giving off the equivalent of 75W of light. You can get these bulbs with full color, though you'll be paying more for the extra colors.
Hue integrates well with most smart assistants and this kit is no different with support for Alexa, Apple HomeKit and Google Assistant. Zigbee is used to connect the bulbs to the hub and the hub connects to your network using Wi-Fi. While investing in a Hue Bridge increases the initial cost of your smart home setup, you can connect other Hue bulbs to it down the line, so you don't need to buy a kit every time. With so many other Philips Hue lights to choose from, it's a strong ecosystem for your smart home.
How to choose
Illuminate your space, whether your want RGB, white, or both
Whether you're trying to light every corner of a dreary basement or just want to see a little better when you're working in the garage after dark, a nice bright light bulb can help without needing to strip a single wire. LED bulbs have allowed for much brighter lighting with less heat and power usage than older bulbs. With smart bulbs, you can even turn them down when you don't need retina-searing levels.
Using a high-lumen smart bulb is a fantastic way to give you a well-lit area and the ability to customize how the light can make you feel. Adding in some smarts to that bulb gives it the flexibility to control from your favorite smart speaker or the best Android phone.
The easiest way to get started is with a bulb that doesn't require a hub to control its smart features. Not only does the Feit Electric OM100 RGBW bulb offer just that — it's also very, very bright. Coming in at 1600LM, it's sure to illuminate almost any space you're in, while at the same time offering a full range of whites and millions of other RGB colors. Similarly, the LIFX BR30 WiFi Color bulb offers an amazing range of colors, but it's a bit pricey.
If you need as much light as possible for a large space, such as a barn or warehouse, pair one of the best smart switches with corn LED light such as the DragonLight 400W equivalent bulb. These are not a good fit for inside your home though.
Regardless of which of these smart LED bulbs you decide to go with, know that all of these lights have the brightness to get your space from feeling dark and gloomy to bright and cheery in no time.
What is a hub and should you buy one?
As the name implies, the hub acts as a central place for all the bulbs to meet up. Using a hub also takes the strain off your Wi-Fi network, but handles all of those bulbs and talks to them directly via a language such as Zigbee or Z-Wave. Hubs have both good and bad sides: On one hand, the hub is an extra piece of hardware to set up and manage. On the other, a hub is often more reliable than Wi-Fi or Bluetooth alone.
Matter is a newer standard that's set to improve interoperability between smart home brands and it's starting to gain traction. Brands like TP-Link, Naoleaf, and many more are already building matter-enabled tech and several mesh Wi-Fi systems, like Nest WiFi Pro, support matter.
Samuel Contreras
When Samuel is not writing about networking or 5G at Android Central, he spends most of his time researching computer components and obsessing over what CPU goes into the ultimate Windows 98 computer. It's the Pentium 3.
