Best Small Android Phones in 2022
The definition of a small phone has changed over the past couple of years as the smartphone industry has moved to taller displays. One way manufacturers have kept phone sizes small is by trimming the bezels, and that's the direction Samsung took with the Galaxy S10e. It's perfect for one-handed use but doesn't skimp on the screen real estate. There are other options, too.
The Galaxy S10e comes in vibrant colors and offers a 5.8-inch Dynamic AMOLED FHD+ display that's perfect for one-handed use. The S10e has a flat display and a fingerprint sensor on the left side. Samsung hasn't compromised on the internal hardware, with the phone sporting the same Snapdragon 855 chipset as the S10 and S10+.
Google has done a stellar job retaining the same form factor as the Pixel 2 while introducing a larger 5.5-inch screen. The Pixel 3 doesn't miss out on any features from its larger sibling — it has dual front cameras, and it also retains the stereo speakers. If you're in the market for a small phone with excellent cameras, the Pixel 3 should be your go-to option.
The Nokia 7.1 is one of the best cheaper phones you can buy today. The phone has a vibrant 5.8-inch display that's certified for HDR10, and the Snapdragon 636 ensures you don't see any lag. Then there's the software — the Nokia 7.1 runs Android One, guaranteeing a clean interface and timely security updates. Best of all, it's available officially in the U.S.
The Honor 10 stretches the definition of a small phone as it comes in just shy of 150mm, but its narrow form factor makes it great to use one-handed. The design at the back is evocative, the phone offers excellent value for money, and the 3400mAh battery is more than adequate for all-day usage.
Nokia standardizes so much of its experience across its entire lineup that it makes it easy to recommend its phones at a variety of sizes. The Nokia 6.1 is just a little smaller than the 7.1, and its lower specs drop its price a tad as well, but you're getting the same clean software (with updates!), and capable specs and cameras for the money.
If we're making some suggestions
The market for small phones is dwindling, but there are a few reliable options still available. The Galaxy S10e brings you the core Galaxy S10 experience in a smaller package and also a lower price. Yes, it's still a little pricey, but if you're after a small, flagship smartphone, it's the way to go.
The Google Pixel 3 also keeps the size down, but its battery life is on the weak side and doesn't have the same pile of features the S10e does. There are plenty of compelling less-expensive options too, like the Honor 10 if you're on a tighter budget.
Be an expert in 5 minutes
