Best Samsung Galaxy S22 chargers
Just about any USB-C cable can charge your Galaxy S22 but to get powered up as fast as possible, you'll need the right charger. The base S22 can charge at up to 25W, while the S22+ and the S22 Ultra can reach charging speeds of up to 45W, but only if you use a charger with both Power Delivery (PD) and Programmable Power Supply (PPS) support. Here are some of the best Galaxy S22 chargers that'll ensure you get the best experience out of your new smartphone(s).
These are the best charging bricks for your S22
Power Delivery brings more choice and flexibility
Samsung's 45W Super Fast Charging Wall Charger is surprisingly affordable, but the lack of folding plugs means it's best suited for a home environment rather than carrying around in your backpack. The Shargeek 65W charger is hard to miss with its bright yellow plastic catching the eye in a sea of matte white and black chargers. It has two ports with an 18W USB-A port and a 45W USB-C port when both are in use. If you're looking for the faster charging possible on one of the best Chromebooks, you can use a single cable for the full 65W of charging. With PD 3.0 charging, this charger can deliver top charging speeds to just about any USB device.
While 45W charging is limited to the Galaxy S22+ and S22 Ultra, you should consider buying a 45W (or higher) charger for the regular Samsung Galaxy S22 as well. 45W is laptop-capable charging speed, so you'll be getting an accessory that's powerful enough to potentially charge every device in your bag during trips — or even at home, if you're living the "one charger to rule them all" lifestyle. It's far better to have a more powerful, widely adaptable charger than one that can only charge your phone in the age of USB Power Delivery.
You'll still only get 25W max speed with a 45W charger on the small Galaxy S22, so don't worry about it breaking your battery. The Programmable Power Supply protocol that Samsung's Super Fast Charging is built on uses a high-quality e-marked cable to negotiate just how much power the charger sends to the phone. You'll need to pick one of these up, too, if your charger didn't come with one, as Samsung only ships a 25W cable with the Galaxy S22.
Rajat Sharma
Contributor
When Rajat got his first Personal Computer—a Pentium III machine with 128MB of RAM and a 56kbps dial-up modem—back in 2001, he had little idea it would mark the beginning of a lifelong love affair with gadgets. That fascination, combined with a penchant for writing and editing, ultimately led to him becoming a technology journalist. Some of his other interests include Photography, Hand Lettering, and Digital Typography. Rajat is also somewhat obsessed with wrist-worn timepieces and appreciates a Casio just as much as a Jaeger-LeCoultre.
With contributions from
