Best Samsung Galaxy Note 20 Ultra cases 2025
Make sure your Galaxy Note 20 Ultra keeps looking like new.
As the last member of Samsung's iconic Note series, the Galaxy Note 20 Ultra is (and will always be) a very special device. The flagship phablet was hands down the most powerful Android device when it launched back in August 2020, crammed with more features than you could shake a stick at. Two years later, it continues to be a top-tier smartphone that will continue to hold its own against the best out there for years to come. So if you're planning to get one (whether new or refurbished) soon, here are some of the best Galaxy Note 20 Ultra cases that'll go perfectly with it. From rugged to minimal, there are lots of options for you to choose from!
Check out these amazing Galaxy Note 20 Ultra cases
Staff Pick
Lightweight and well-made, Spigen's Rugged Armor is easily the best protection your Galaxy Note 20 Ultra can get. Made using flexible TPU material, it uses "Air Cushion" technology to ensure improved shock absorption against scratches, bumps, and hard falls. The carbon fiber design makes it a looker, and you also get tactile buttons that are super easy to press.
Rugged protection
With a phone as premium as the Galaxy Note 20 Ultra, getting a rugged case makes perfect sense, and ArmadilloTek's Vanguard series is a no-brainer. Designed to comply with military-grade standards, it can protect your phablet from drops as high as 21 feet. You get raised lips around the screen and rear camera array, as well as a built-in kickstand.
Stylish and tough
Caseology's Parallax series has long been our favorite, and that isn't changing anytime soon. The unique 3D pattern on the back panel not only looks stunning but also helps with the in-hand grip. Protecting the inner TPU shell is a polycarbonate bumper, giving your phone reliable military-grade protection. Of the available colors, Aqua Green and burgundy are our favorites.
Transparency with some color
Want to show off your Galaxy Note 20 Ultra's gorgeous back panel while still keeping it protected? Get the i-Blason Ares. It is made from TPU and polycarbonate and rated against drops as high as 20 feet. Featuring precise cutouts for all openings and ports, the case supports wireless charging too. The back is all clear, and you can choose between red and black colors for the bumper.
Slim, minimal, and tough
The Galaxy Note 20 Ultra is already a behemoth of a phone, so a thin case definitely makes sense. We suggest Spigen's Thin Fit, which is so minimally designed you won't even feel it's there. It is made of scratch-resistant polycarbonate and TPU, so you still get reliable protection without bulking up the already large phablet even further.
Carries more than just your phone
With Snakehive's Vintage Wallet case, you no longer have to worry about forgetting your actual wallet at home. Handmade in Europe, it comes with three slots on the inside of the top lid for all your ID/debit/credit cards, as well as a cash pocket. The case also includes a built-in kickstand for landscape viewing and is available in a variety of colors like Plum and navy.
Prop it any way you want
Thanks to its huge 6.9-inch Dynamic AMOLED panel, the Galaxy Note 20 Ultra is perfect for things like multimedia consumption and video calls. And this kickstand case from ESR is great for the same. Its all-clear design lets you flaunt your phablet's back panel, but the real highlight is the kickstand case that works in both portrait and landscape mode and can be adjusted by up to 60 degrees.
With anti-microbial protection
Speck is a name that needs no introduction when it comes to phone cases, and the Presidio2 Grip shows why. Thanks to its "Armor Cloud" technology, the case protects your Galaxy Note 20 Ultra from up to 13-foot high drops by acting like an airbag. Not just that, Speck's "Microban" technology prevents the build-up of bacteria on the case's surface.
Clear and affordable
Ringke's cases are known for offering style and protection at a very reasonable price, and the Fusion series is no different. The clear case is made from of TPU and polycarbonate and comes with raised lips to protect your Galaxy Note 20 Ultra's huge display from scratches and scuffs. You can also attach a lanyard or neck strap with the built-in holes, and there's full support for wireless charging thrown into the mix.
Fabric-like finish
The Denim Patchwork from SQMCase — as its name suggests — has a denim-covered back that gives it a great in-hand feel. The case is quite lightweight and fully covers all the buttons without affecting their tactility. You get adequately raised lips around the screen and rear camera array for added protection, as well as wireless charging support.
Different colors, same protection
Having the right balance of style and protection, Crave's Dual Guard series is an easy recommendation for the Note 20 Ultra. The case's slim and compact profile allows it to easily slip in and out of pockets without adding too much bulk, and you also get a lifetime warranty for peace of mind. Some of the color options on offer include berry, lilac, and Slate.
Hidden compartments, magnetic closure
GOOSEPERY's card holder is hands down the most unique and funky-looking case of its kind that we've seen. Its entire back panel is a magnetically-secured lid (complete with a cutout for the rear camera array) that opens to reveal a compartment for credit/debit/ID cards. The case is made from polycarbonate and TPU material, and the back lid is available in numerous colors.
Make your Samsung Galaxy Note 20 Ultra last for years
It may be nearly two years old at this point, but Samsung Galaxy Note 20 Ultra can still give some of the best Android phones a run for their money. While it's not easily available these days, you can snag one refurbished (or even new) from third-party retailers if you search a bit. Still a great buy in 2022, the phablet is going to last years with no issues if you choose to buy it, but we do recommend getting a case to keep it protected. Our top vote goes to Spigen's Rugged Armor which has a lightweight yet tough construction. The Carbon Fiber design looks great, whereas the "Air Cushion" technology means you don't have to worry about hard falls and scratches.
If you don't want to take any chances with your premium phablet and wouldn't mind adding a little heft to it, take a look at ArmadilloTek's Vanguard series. Thanks to its rugged design, it can protect the Note 20 Ultra even if it were to fall from a height of 21 feet. The built-in kickstand is also a nice addition, making binge-watching movies and TV shows a hassle-free affair. And once you've decided which case to get, you might want to take a look at some of the best Samsung Galaxy Note 20 Ultra screen protectors to shield that vibrant 6.9-inch display from scratches, scuffs, and fingerprints.
Be an expert in 5 minutes
When Rajat got his first Personal Computer—a Pentium III machine with 128MB of RAM and a 56kbps dial-up modem—back in 2001, he had little idea it would mark the beginning of a lifelong love affair with gadgets. That fascination, combined with a penchant for writing and editing, ultimately led to him becoming a technology journalist. Some of his other interests include Photography, Hand Lettering, and Digital Typography. Rajat is also somewhat obsessed with wrist-worn timepieces and appreciates a Casio just as much as a Jaeger-LeCoultre.
- Namerah Saud FatmiSenior Editor — Accessories
