Best rugged Android phone
Boil 'em, mash 'em, stick 'em in a stew — these are the best rugged phones.
Modern phones are actually a lot sturdier than they may seem. Advancements in technology have led to stronger metals, plastics, and glass which are commonly used on most phones today, cheap and premium. But sometimes, you need that extra level of protection or rigidity that only rugged phones can provide.
The best rugged Android phones might not have the most attractive designs or specs and yet, may cost as much as a high-end flagship. But you're paying a premium for their longevity and the ability to survive the harshest of environments.
The best overall phone is the Samsung Galaxy XCover 7 Pro. It has 5G, a removable battery, and even supports Samsung DeX for advanced productivity when you're out on the field. If you need better features or a much larger battery, we've got many more great options for you to choose from below.
At a glance
Best overall
The Samsung Galaxy XCover7 Pro comes with 5G connectivity, a removable battery, and even Samsung DeX support, making it an all-around champion.
Runner up
The HMD XR21 is a well-rounded smartphone and a solid follow-up to the Nokia XR20. It sports a tough design, upgraded specs, 5G support, and 33W fast charging. It's the same as the Nokia XR21 but with wider U.S. availability.
Best value
The Moto G Power 2025 comes with a MIL-STD-810H rating for toughness and is also IP68/IP69 rated for extreme waterproofing, making it the most durable phone under $300 from a big brand.
Best battery
With its massive battery, the Ulefone Power Armor 27T Pro can go on for days once fully charged. There's also a 4G version for $150 less if you wish to save a bit.
Best compact
The Doogee Smini has NFC, 256GB of onboard storage, a handy secondary display, and more in a palm-sized chassis.
Best budget
The Oukitel WP35 offers a lot of modern features for the price, making it an excellent budget pick. It runs Android 14, has a Full-HD IPS display, and a massive 11,000mAh battery.
Best overall
1. Samsung Galaxy XCover7 Pro
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
While Samsung's flagships are undoubtedly among the best Android phones available out there, they're all quite fragile. If you want something that's a bit more rugged from the brand, look no further than the Galaxy XCover7 Pro.
Powered by Qualcomm's Snapdragon 7s Gen3 SoC, the Samsung Galaxy XCover6 Pro features 6GB of RAM and 128GB of internal storage, with the latter being expandable via a microSD card. Its 6.6-inch TFT LCD panel may not compare to the AMOLED screens found on top-of-the-line smartphones, but the display is still sharp and big enough for everyday tasks. It's also secured with a layer of Corning's Gorilla Glass Victus+ for improved protection against any and all kinds of damage.
The smartphone complies with the MIL-STD-810H standard, which means it can survive being dropped from a height up to 1.5m. It's also backed by an IP68 rating for water and dust resistance.
Benefiting from Samsung's excellent software update policy, the Galaxy XCover7 Pro will be updated (at least) to Android 16. It features a dual-lens rear camera system with 4K video recording. Rounding off the spec sheet is a removable 4,350mAh battery with 15W fast charging support.
Runner up
2. HMD XR21
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
The HMD XR21 is a rebadged Nokia XR21, with wider availability in the U.S.. It has the same specs and features as the Nokia, but is a lot more accessible. It's a smart-looking device with its ultra-rugged design, IP69K-rated dust and water resistance, as well as military-grade construction. You also get a 3.5mm audio port and a microSD card slot, which are big pluses in today's world.
The XR21 has biometric unlocking and will be supported until 2026 with Android OS upgrades. Since most rugged phones hardly get one platform update, it's leaps and bounds ahead of its competition. The big battery can be charged via USB-C at 33W, and the 64MP primary sensor should be able to get you decent images.
Unlike most rugged Android phones on the market, the HMD XR21 doesn't embrace the heavy-duty aesthetic and opts for a lighter, more mature form factor. Compared to the Nokia XR20, the new model is lighter, has a 120Hz display, gets a more powerful Snapdragon 695 SoC, a larger battery, and higher resolution main and selfie cameras. Overall, this is still one of the better rugged phones available in the market right now, even more so if you can get it at a discount.
Best value
Specifications
Reasons to buy
Reasons to avoid
The Moto G Power 2025 takes the spot of the AGM H5 Pro as the 'best value' rugged phone thanks to better features and longer software support at a similar price. It costs just under $300 for a single variant with 8GB RAM and 128GB storage, and the latter is expandable with a dedicated microSD slot. The two most important features that put the Moto on our list are the MIL-STD-810H certification for toughness and the IP68/IP69 rating for extreme water resistance. This is currently the only phone at this price from a big-name brand to offer such durability certifications, which makes it unique.
As for performance, the Moto G Power 2025 works just fine as a daily driver, although the interface can feel a bit sluggish at times. The MediaTek SoC is not the most powerful so this isn't the phone to get for running heavy apps and games. The cameras are also strictly okay and are good enough for social posts, but that's about it. Battery life is one of its strong suits as it can deliver multi-day battery life if used frugally. There's 30W fast charging and even 15W wireless charging, which is amazing.
Unlike the AGM, the Moto supports 5G on all major U.S. carriers and comes with Android 15. Motorola has also pledged two major OS upgrades for this phone, which means it should updated to Android 17 next year.
Best battery
4. Ulefone Armor 27T Pro
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
When looking for the best rugged Android phone, you'll want something that lasts all day, has plenty of extra tools to make life (and work) easier, and has enough power to handle everyday tasks. Ulefone's Armor 27T Pro delivers on all these fronts as it offers a thermal camera, which is just one of the many built-in goodies it comes with.
Powered by MediaTek's Dimensity 6300 SoC, the Armor 27T Pro has 12GB of RAM, 256GB of internal storage, a large 6.78-inch display, and a gargantuan 10,600mAh battery. The heavy-duty phone touts IP69K water and dust resistance, and an enduring design that is compliant with the MIL-STD-810G standard.
Impressively, Ulefone Armor 27T Pro features 33W wired, 30W wireless, and even 5W reverse wireless charging. This means you can top up other devices or phones that charge wirelessly with this thing. It also supports 5G, making it compatible with modern networks. Ultefone also has a 4G version with the same features but a Helio G99 SoC for under $400.
Best compact
5. Doogee Smini
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
It's nigh impossible to find a smartphone these days that can be used with one hand, which is why we're glad that something like Doogee Smini exists. If you despise huge devices and want something that's both tough and pocketable, this is the answer.
Measuring 5.24 x 2.36 x 0.53 inches and weighing a mere 5.47 ounces, the Smini is a compact wonder. It's driven by a MediaTek Helio G99 chipset and comes with 8GB of RAM. You also get 256GB of internal storage, which is expandable up to an incredible 2TB via a microSD card. The smartphone's 4.5-inch IPS LCD panel might take some time getting used to, but it works well for what it is. You even get a nifty secondary display on the back that shows information like battery level. Compliant with the MIL-STD-810H standard, the Smini also comes with an IP68 rating for water and dust resistance.
Doogee's software update policy isn't exactly the best out there, which means the Smini will probably remain on Android 13 forever. The company's phones also tend to slow down over time. That said, you do get a dual-lens primary camera setup, along with goodies like NFC payments, face unlock, and a 3,000mAh battery with support for 18W fast charging.
Best budget
6. Oukitel WP35
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
Most rugged phones tend to have some sort of compromise or the other like a low resolution display, no 5G, or are simply too bulky. The Oukitel WP35 is one of those exceptions that offers regular smartphone-like luxuries at an affordable price. This rugged phone has IP69K and MIL-STD-810H ratings and isn't too unsightly to look at. You actually get a choice of colors, which is not something we see often.
Under that tough exterior are modern specs which are quite respectable for 2024. The WP35 is powered by the MediaTek Dimensity 6100+ 5G chipset and comes with 8GB of RAM and 256GB of storage. The latter is expandable by up to 2TB using a microSD card. The phone also has a massive 11,000mAh battery with 18W fast charging, and Oukitel has managed to keep the thickness down to 15mm.
The cameras on the Oukitel WP35 are also quite impressive, well, most of them anyway. There's a main 64MP Sony IMX682 sensor for main camera duties and an 8MP night vision camera. There's a third 2MP macro camera, but I wouldn't put too much stock in that one. The selfie camera should be quite capable too with a 32MP Sony IMX616 sensor.
How to choose
If we had to make a rugged choice
All of the above-mentioned best rugged Android phones are great in their own right, but if we had to pick a winner, it'd be Samsung's Galaxy XCover7 Pro. While not really a flagship, it comes with more than decent hardware that's capable of making quick work of just about anything you throw at it. It also has a removable battery, which is a rarity these days, and is backed by an excellent software update policy.
In fact, the XCover7 Pro can even hold its own against a mainstream value-for-money device like the Google Pixel 9a. We also suggest checking out HMD's XR21, which continues to be a fairly good option despite being a little old at this point. It won't get any updates beyond Android 14 but features like wireless charging and stereo speakers make it a solid choice. The Moto G Power 2025 might not look the part but it's built tough just like the others with all the right certifications in place. Plus, it's also the most up-to-date phone on this list if having the latest Android flavor matters to you.
If you're not a fan of bulky smartphones, you're going to love Doogee's Smini. Much smaller than the best small phones currently available in the market, it comes with features like a secondary display on the back, 256GB onboard storage that you can expand up to 2TB, and NFC for hassle-free payments. Finally, the Oukitel WP35 is a great budget pick for anyone looking for modern specs and a massive battery, in a slim and affordable form factor.
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
- Roydon Cerejo Contributor
- Rajat Sharma Contributor
