Best Bands for TicWatch Pro 2022
TicWatch Pro
TicWatch Pro (Image credit: Android Central)
The TicWatch Pro is a fabulous smartwatch, but like most watches, the bands will eventually get worn out. It's a natural occurrence and an annoying one at that. Fortunately, you can easily replace these 22 mm bands. All you have to do is find the one that's right for you. Whether you're looking for a fitness-friendly band or one that allows you to dress up your smartwatch for formal events, there's plenty more where that came from. Check out some of the best TicWatch Pro replacement straps for your wearable!
Best TicWatch Pro replacement straps Which should you buy?
This might go without saying, but the best TicWatch Pro replacement straps are the ones that will look good, allow your wrist to breathe, and are easy to attach. This is exactly why we recommend the Mobvoi Genuine Leather Watch Band as the best overall option. The combination of two preferred materials, leather, and silicone, gives you the best of both worlds. Not to mention that it's also compatible with other TicWatch models.
However, if you're looking for a more fashionable alternative, then we have two other bands in mind. Go with the OTOPO Genuine Leather Band for a true leather band that's suitable for all occasions. Then there's the Koreda Stainless Steel + Mesh Loop Bands if you want to get fancy. You also get two for the price of one, which is an amazing deal. If fitness is the name of your game, any of the silicone or nylon bands are solid choices.
The good news is that the new TicWatch Pro 3 is also compatible with 22 mm interchangeable bands, which means you can use any of these bands if you eventually decide to upgrade to the new model.
Courtney Lynch
Courtney Lynch is a freelance writer at Android Central. She's obsessed with all things health, fitness, and music. At any given time, she can be found checking out the latest and greatest gadgets while simultaneously petting her dog and sipping iced coffee.
