Best Oculus Quest & Quest 2 controller batteries 2025
Keep your Oculus Touch controllers powered up.
The Touch Controllers for the Oculus Quest 2 ship with one disposable AA battery each. That initial battery will last for a while if you don't play with your Quest 2 very frequently — up to several months, in fact. However, it's wise to get one of the best Oculus Quest 2 replacement batteries so you can keep playing once they eventually run out of juice.
If you're going to buy disposable batteries, it's worth purchasing a larger stack rather than a standard sized pack to save some money and ensure you'll have a supply whenever you need to swap a battery out. Or, better yet, invest in a charging station or rechargeable batteries to get even more bang for your buck! Here are the batteries and chargers we recommend for your Oculus Touch controllers.
The best battery and charger options for your Oculus Quest controllers
Best rechargable batteries + charger
These rechargeable batteries store up to 2,000 mAh of power and can be recharged up to 2,100 times. They can even safely be recharged when the battery is just partially depleted without damaging the energy storage memory. We recommend buying them with the quick charger accessory, which will get your AAs recharged in three hours or less, but you can also purchase the batteries alone for half the price if you already have charger.
Extra battery potential
Storing up to 2,550 mAh of energy and able to be recharged 500 times apiece, these eneloop pros will give your Oculus Touch controllers even more time between play sessions before needing to be swapped out. While they have significantly fewer recharge cycles than the non-pro batteries, they also give you the added convenience of not having to recharge them often and should still last for several years. Make sure to invest in the charger if you need it.
Never open them again
This unique charge kit comes with two special batteries, form-fitting covers, and special recharging cables. Each battery has a small magnetic connector that fits through the opening in the battery cover, making it easy to recharge each controller when the battery gets low. If you pair this with one of the BeswinVR controller grips in the same Amazon listing below — which features that same cut-out for the charging port — you won't even need to remove your grips to charge your controllers.
Dock it up
With its nearly $100 price point, the Anker Charging Dock for Quest 2 might be hard to justify at first glance. However, it's one of the coolest accessories you'll find for the VR headset. Thanks to the series of safety components inside, you can dock both your headset and controllers in its form-fit design without having to worry about overcharging or overvoltage. Just be aware that you'll need to remove any controller grips before docking. That's an annoying caveat, but at least you only need to charge these batteries once every few months.
Charging Panasonic batteries
This charger will take your Panasonic eneloop batteries from dead to charged in just up to two hours. It has an LED indicator to help you know when your batteries are done charging, and automatically shuts off to protect your batteries. It's a must-have if you're using Panasonic eneloop batteries.
Keep going and going
These Energizer batteries are both affordable and dependable. They sport a five-year shelf life, 1,000 recharge cycles, and 12 months of charge retention. The 2,000 mAh may not be ideal for electronics with higher power demands, but should be more than sufficient for the energy-efficient Oculus Touch controllers.
Universal battery charger
This smart charger will charge up to four Ni-MH or Ni-CD AA batteries. The LCD screen shows the current charge level of each battery individually, detects non-rechargeable and defective batteries, and protects against accidents like overheating and short-circuiting. Best of all, it can also charge AAA batteries!
Rechargeable and budget friendly
These rechargeable batteries are budget-friendly and still have a large 2,400 mAh capacity. They'll maintain 70% of their original capacity for up to six months, so after you're finished with the two in the Touch Controllers, you'll still be able to use the other two from the pack with a decent charge. We don't know how many recharge cycles they're predicted to keep their full charge but Amazon says at least "three years," which should last you until the Oculus Quest 3 arrives.
Best lithium disposables
These batteries have a massive 3,000 mAh capacity, and can last up to 20 years in storage. They are also able to perform in extreme temperatures ranging from 40 to 140 degrees Fahrenheit. You probably aren't using your headset in those temperatures, but you can take a couple from the four-pack for your Oculus Quest, and two others for more extreme conditions. Keep in mind that they aren't rechargeable, but do last longer, are cheaper in bulk, and won't force you to buy a charger.
Best alkaline disposables
These batteries last up to 10 years in storage, so you can grab a pair out of the drawer and keep your Touch Controllers powered and ready to go. They're leak-resistant, which helps protect your hardware, and the 24-pack is available for a budget-friendly price. The Oculus Touch controllers don't demand a lot of power, so this pack of 3,000 mAh alkalines should last you for years if you only use them for your Oculus Touch controllers.
Great bargain
These batteries come in a 72-pack that costs around the same price or less than name-brand battery 48-packs. They're leak-protected to guard your device and can hold power for up to 10 years in storage. We guarantee you won't need all of these for your Touch, but this is a great bargain if you need AAs for your other controllers or devices.
High capacity, low discharge
These eco-friendly batteries have a large 2,800mAh capacity and can be charged over 1,200 times. They're explosion and leakproof, so you won't have to worry about any accidents thanks to that extra security. Best of all, they keep 70% of their charge after three months of non-use.
Don't let batteries hold your Quest gaming back
As wireless headsets with wireless controllers, the Quest and Quest 2 headsets don't have particularly long battery lives. While the headset can simply be recharged with the included cable, the Touch controllers are a different story entirely. You'll need to replace the controller batteries at some point, especially if you play frequently.
That's why we recommend getting rechargeable AA batteries, as you'll be able to easily have a pair handy when the batteries get low, and will have plenty of warning ahead of time. The only thing worse than having to stop playing the best Oculus Quest 2 games to replace your batteries is not to have any spare batteries to swap in.
When picking the best Oculus Quest 2 replacement batteries, pay attention to any information they give on recharge cycles and usable battery life. You'll want at least 500 recharge cycles and several years of promised durability to ensure your battery won't suddenly stop working or lose its charge. That's one reason why we love the Panasonic eneloop rechargeable batteries, which can recharge an absurd 2,100 times before you'll finally have to buy some new ones.
Battery capacity is also an essential factor to consider, though perhaps not as vital as you might think. The higher mAh rating you see, the longer the battery will last and the more it can handle demanding electronics. But the Oculus Touch controllers aren't that demanding and are frequently in standby mode. Since standby mode doesn't use any real power, it's important to get batteries that can hold their juice for a long time, even when not in use.
For reliable performance in both areas, the Panasonic eneloop Pros have a solid 2,500 mAh while also retaining 85% of their charge for a whole year. Or, if you don't want to bother with rechargeable batteries, the Energizer Ultimate Lithium batteries have a massive 3,000 mAh capacity, and can last up to 20 years in storage.
If you were looking for something a little more bespoke than generic AA batteries, both Anker and BeswinVR offer charging docks or special cables and batteries that'll get the job done without having to ever remove the battery cover again. They're a bit more expensive than regular batteries but shouldn't ever need to be replaced while you have your Quest 2, thanks to battery longevity.
Once you've chosen the batteries you need, look into ways to make sure your headset is staying properly charged as well. You can look into the best Oculus Quest 2 battery packs to attach to the Quest 2, or buy a replacement Quest 2 charging cable that'll keep you topped off as you play.
Be an expert in 5 minutes
Nick is a freelance journalist and games reviewer with a passion for RPGs, bad puns, and VR. When he isn’t guesting on podcasts or streaming on Twitch, he’s probably playing Borderlands with his husband.
- Nicholas SutrichSenior Content Producer — Smartphones & VR
- Sean Endicott
