Best Meta Quest 3 & 3S accessories 2024
Most of the best Meta Quest 3 accessories also work for the Quest 3S; these upgradeable headsets get much better with new straps, pads, and other mods.
Meta gave the Quest 3 and 3S modular designs to easily install accessories, which is a double-edged sword. You can add more comfortable straps, double your battery, add lens inserts with your prescription, make the controllers easier to grip, and other useful mods; the downside is that if you use Meta's official accessories, all this could double the price of the headset, too.
Why bring up both the Meta Quest 3 and Meta Quest 3S? Because Meta designed them so that most of their accessories are interchangeable. This guide was originally written for the Quest 3 alone, but nearly all of our picks work for the Quest 3S.
You can check Quest 3S accessory guide to get specific, but basically all of the Elite headset straps, controller straps, cases, USB-C headphones, and Link cables will work with the Meta Quest 3S — though not 3.5mm headphones or facial interfaces.
Our guide on the best Meta Quest 3 accessories will highlight our favorites from trusted third-party makers like BoboVR and AMVR that we've personally tested and that work as well as Meta's official mods, but for significantly less! New Quest 3S owners or Black Friday VR deal hunters should keep an eye out for our favorites for even lower prices.
Nick has played with VR headsets since the Virtual Boy and knows what's good and what's not. He writes a weekly column called AC thVRsday covering the industry in general and the Quest 3 specifically, and he's hand-tested most of the accessories on this list, along with plenty of others not worth including.
At a glance
Best overall
Best overall
Over the years, BoboVR has become a legendary name in the Meta Quest community, making some of the best head straps you can buy for any VR headset. The Quest 3 model of its flagship line includes new swivel options and the classic magnetic battery pack on back.
Best premium
Best premium
While a little more expensive than the BoboVR strap, the Kiwi Design head strap is a new staff favorite thanks to its incredible comfort and plenty of extra battery capacity, with a unique dual-charging feature for a faster recharge.
Best grips
Best controller accessory
These upgraded controller grips add a sweat-resistant soft outer layer to your Meta Quest 3 controllers as well as a hand-gripping strap that lets you better throw and hold things in comfort in VR.
Best Elite Strap
Best Elite Strap
If you don't need a battery pack and just want an affordable comfort upgrade, this is where to start. Zybervr designed it with a flexible viewing angle, plenty of padding, and a reasonable price.
Best face cover
Best face cover
The default Quest 3 interface is really susceptible to foggy lenses and sweat-stained cloth. AMVR's option is the best option for proper ventilation that we've found.
Best headphones
Best headphones
Never bother with those unwieldy cans or wires again! PrismXR Vega T1 earbuds were made for VR, featuring a special USB-C dongle that delivers wireless sound with zero lag and passthrough 30W charging.
Load the next 3 products ↓
Best link cable
Best link cable
Dedicated Meta Quest 3 games are great but, sometimes, it's just nice to get that extra graphical and performance oomph from a gaming PC. Use this long cable and do it in style!
Best case
Best carrying case
The Meta Quest 3 was built to be portable, so why not get a carrying case that'll keep it safe along the way? The KIWI Design carrying case looks amazing and has plenty of space for your Quest 3 and some extra accessories.
Best for glasses
Best for glasses-wearers
Anyone who wears glasses knows how annoying (and dangerous) it is to have your lenses meet the headset. These lens inserts from Virtu Clear will let you enjoy VR without the hassle of contacts.
These are the best Meta Quest 3 accessories you can buy
Best overall
1. BoboVR M3 Pro
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
Works with Quest 3 and Quest 3S
BoboVR has been making many people's favorite Quest 2 head straps for a few years, and now that product has been upgraded for the Meta Quest 3. This replaces the flimsy cloth strap that ships with the Quest 3 and makes it much more comfortable to wear.
To start with, the BoboVR M3 Pro shakes things up by taking all the weight off your face and evenly distributing it between your forehead and occipital bone. That makes it far more comfortable to wear it for long periods of time, and it also means you can wear your Quest 3 without the face pad if you so wish.
Extra comfort serves a double purpose since the BoboVR M3 Pro ships with a rechargeable, magnetically-detachable battery pack that can be hot-swapped at any time. Each pack adds about 2 hours to the Quest 3's battery life, meaning you can play for hours at a time without worrying about low battery notifications.
Best premium
2. KIWI design H4 Boost Battery Head Strap
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
The Kiwi Design H4 Boost Halo strap could easily claim the top spot on this list, but since Quest 3S owners in particular will want to save money on accessories, we slotted this more expensive option into the second slot if you're willing to splurge.
This latest halo-style headstrap from Kiwi Design builds upon years of VR accessory experience with the most comfortable design I've ever used, thanks to its extra padding, cooling pad, and adjustable forehead pad that lets you adjust the angle.
Its 5,300mAh capacity — adding about 2.5 hours of extra play time — is larger than the Quest 3's capacity or the official Quest 3 battery pack, and it has a unique charging trick with dual USB-OD chips: If you plug a 45W-capable USB-C cable into the strap, it'll split the power to both the Kiwi Design H4 and Quest 3 simultaneously, charging them both that much more quickly.
Even though you can't swap out the battery like the BoboVR, you can still get 2+ more hours of playtime after an hour of charging.
Best controller
Specifications
Reasons to buy
Reasons to avoid
AMVR's Touch Plus controller grips are good enough that you'd assume they were official accessories — while charging half of what Meta's official Active Straps cost.
Like the company's Quest 2 grips, these Quest 3 & 3S grips feature a clever battery slot so you can swap out low batteries without having to take the grips off the controller. Plus, AMVR is one of the only companies making grips that didn't cover up that lower tracking LED near the base, so these won't negatively affect tracking quality at all.
The extra soft material not only adds grip to the Touch Plus controllers but it's got a nice powdery finish, helping to ward against sweaty hands. And who could forget about those fantastic hand grips that make it possible to throw things in VR without throwing the controllers?
Plus, they work as an excellent counterweight to better stabilize the smaller controllers in your hands. It's a win, win, win all around.
Best Elite Strap
4. Zyber Elite Strap
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
While we recommend the BoboVR M3 VR for its comfort upgrade and its battery boost, it's fairly pricey and sometimes goes out of stock. If you need a more affordable alternative, the ZyberVR head strap is the one to beat, solely from a comfort standpoint. You'll just have to accept the Quest 3's 2-hour battery or the Quest 3S' 2.5-hour battery.
Instead of just a back knob for better security and a thicker top strap for support, Zybervr put extra thought into the design by putting the back TPU portion higher on the back of your head and pointing the strap downward towards a hinge, so gravity pushes it onto your head instead of off it.
You can also adjust the angle of the front portion to make sure your eyes have the perfect angle for a clear view, using a rotation button to make adjustments on the fly. Having tested it for ourselves, we're really happy with the overall experience and highly recommend it.
Best face cover
Specifications
Reasons to buy
Reasons to avoid
Quest 3 only
The plush facial interface that ships with the Meta Quest 3 feels great on the skin but has some issues. One, it's cloth, so it absorbs sweat if you're more of an active Quest gamer. Two, we've noticed a significant ventilation issue, leading to foggy lenses.
You can solve the first problem with an inexpensive silicone cover — the APEXINNO silicone face cover costs less than $10 and works well — but to solve the second, you need to replace the facial interface entirely. That's not difficult on the modular Quest 3, but you need the right interface to make it worth your time. Enter AMVR's facial interface.
Its PU leather is very soft, cool, comfortable, and sweat-wicking, a great pairing option with a new Elite strap like the Bobovr or Zybervr. More importantly, the ventilation along the edges gives you a pretty adequate countermeasure against lens fog, even if it doesn't fully remove it like the Quest 2 Kiwi interface did. We hope Kiwi Design makes a Quest 3 version soon, but the AMVR option is the best we have for now.
Another benefit to AMVR's option is that it makes the headset backwards compatible with your old Quest 2 silicone face covers, which don't fit the Quest 3 interface easily. The default AMVR cover attaches with velcro, making it easy to remove, clean, and reattach.
We hope AMVR will release a unique Quest 3S facial replacement; for now, we can only point you to the official Breathable Facial Interface.
Best headphones
6. PrismXR Vega T1 earbuds
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
Some products are nearly impossible to improve upon. PrismXR Vega T1 earbuds fit right into that elusive category, delivering the best wireless audio quality of any made-for-VR earbuds you'll find today. These earbuds not only sound incredible but also deliver zero latency thanks to the ingenious USB-C dongle that plugs into your Quest 3 or 3S USB-C port.
PrismXR Vega T1 earbuds come with a handy storage case that doubles as a power bank for them, ensuring that your earbuds are always charged and ready to go. There's a USB-C connection on the case and a handy LED to let you know when the case's internal battery is getting low.
Plus, PrismXR was thoughtful enough to include a USB-C passthrough port on the dongle so you can still use your battery head strap and the earbuds at the same time. The best Quest 2 earphones, the Soundcore VR P10, charge at a slower rate but PrismXR Vega T1 will charge your Quest 3 or 3S at the full 27W rate when plugged into a battery or a head strap like the BoboVR M3 Pro.
Since Meta eliminated the 3.5mm headphone jack on the Quest 3S, a USB-C passthrough dongle is the only way to have private audio while gaming, making the PrismXR Vega T1 a near-necessity if you don't want to annoy loved ones or roommates.
Best Link cable
7. Syntech Meta Quest Link cable (16ft)
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
Syntech's Meta Quest Link cable is one of the highest-rated cables on Amazon, and I've used it long enough to confirm that it's a quality product. The standard 16ft (5m) length cable is plenty long for most setups, as it'll let you walk around your room quite a bit before running out of slack. But, if that's not enough, Syntech sells several longer lengths that might work better for your personal setup.
While the official Quest Link cable from Meta is far more expensive and only supports a USB-C to USB-C connection, this cable is a fraction of the price and has a USB-A port on the PC end, granting compatibility with a wider range of systems. Some PCs have plenty of USB-C ports but USB-A ports often go unused these days thanks to the proliferation of USB-C peripherals.
In addition to being well-built, this cable has a great data transfer rate and provides plenty of power to keep the headset powered while playing PCVR games. That's important because lots of cables don't provide enough power to the headset, causing it to slowly discharge over long play sessions.
But note that the performance and wattage output depend entirely on your PC. If your ports don't support USB 3.1 or won't output the full 18W (9v/2a), you won't be able to take full advantage of this cable's abilities. Still, having a cable can be one of the simplest ways to get into PCVR with a Meta Quest 3 or 3S headset.
We also have a full guide on Quest Link cable alternatives if you want to look at other options, but Syntech is a great starting point.
Best carrying case
8. KIWI Design Meta Quest carrying case
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
KIWI Design's carrying case is made for the Meta Quest 3, 3S, or 2 (and even the Vision Pro). It'll perfectly fit whichever headset you buy and its Touch Plus controllers, with plenty of room to spare. Yes, that even includes some of those bulkier battery head straps that take up more room!
KIWI's case looks absolutely fantastic on the outside, and it's built well, to boot, keeping your Quest 3 & 3S protected even if you accidentally drop the case. It's got dedicated spots for the controllers right in the middle and even includes a handy lens protective cover so rogue accessories can't scratch up those precious lenses.
There's also additional storage inside for extra accessories like cables and batteries, making this a fantastic deal. Since it has plenty of room, it almost encourages you to buy a fancier strap than Meta's default cloth one. If you'd rather stick with the smaller head straps, grab this super compact VORI Quest 3 carrying case, instead.
9. Zenni Optical prescription lenses
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
The Meta Quest 3's improved facial interface can be easily adjusted to fit many different types of prescription glasses, but using that has some major downsides. And with the Quest 3S, you'll likely need some kind of spacer. Either way, you're forced to keep the lenses further away from your face, reducing your field of vision while gaming.
Ditch the hassle and grab these inexpensive prescription lenses built for the Quest 3 or Quest 3S, instead! These lens filters pop directly onto your headset lenses and can be removed when sharing the headset with others. Since they're made-to-order, they fit your prescription perfectly and make using the headset far nicer than using your glasses.
Plus, they're water and scratch-resistant, have an anti-glare coating, and are endorsed by Meta for official compatibility. Just make sure that you choose the right lenses to match your headset: the Quest 3S and Quest 3 lenses aren't interchangeable.
How to choose
Browsing Amazon for the best Quest 3 accessories can lead to a lot of confusion. Lots of unknown brands make similar-looking products and often are only differentiated by price. When in doubt, we recommend sticking to a few tried-and-true brand names: KIWI Design, AMVR, BoboVR, and Zyber.
These four companies have all proven that they can regularly make excellent products that stand on their own and offer better quality and unique features. Ironically, all of them seem to do a better job of making Quest 3 & 3S accessories than Meta itself, as most of Meta's accessories are either overpriced or poorly made.
When looking for a Quest 3 or 3S head strap, you'll find they generally come in two styles: elite or halo. Elite-style straps are similar to the official Meta Elite Strap product but the ones we recommend from Zyber and KIWI Design sport a higher quality plastic and more features. Halo-style straps are similar to the PlayStation VR which used a thick forehead pad to offset the headset weight from the face.
We recommend everyone get a headstrap with a battery to ensure longer play sessions, but not everyone wants the added weight of an extra battery. Know that the BoboVR straps come with removable batteries which make it the best choice no matter what your needs are.
Controller straps are all fairly similar in shape and design because the smaller Quest 3 & 3S Touch Plus controllers don't offer manufacturers as many style options as the Quest 2. As such, simplest is usually best which is why we recommend both of AMVR's styles. These add a strap that goes around the back of your hand, helping to offset the weight of the controller and also serving to keep it from flying across the room if you let go.
My personal favorite are the regular AMVR controller grips, which swap out the battery door with a handy strap and don't add any extra bulk. Some folks might prefer the added grip of the silicone AMVR upgraded controller grips, though, which are just a few dollars more.
Moving on through the list, PrismXR Vega T1 earbuds are best for Quest 3 because they offer full 30W passthrough charging so you can keep your Quest 3 charged while playing. And when you're taking the Quest 3 on the go, we prefer KIWI Design's case because it's extra roomy and fits accessories like battery packs as well as your headset.
Quest 3 & 3S accessories you might also want
Both the Quest 3 & 3S headsets and the Touch Plus controllers have a ton of accessories, too many to keep our "best accessories" list manageably short. So we're including some other great alternatives and novelty picks, in case the picks above go out of stock or you're looking for something unique.
These other best Quest 3 & 3S accessories will make the best Meta Quest games that much more immersive.
Another BoboVR alternative
We seriously considered the YOGES Battery Head Strap as a replacement for the BoboVR or Kiwi Design straps at the top of our guide, simply because it's another comfortable option that's lightweight and adds 6,000mAh extra capacity — though it's not hot-swappable.
Charging in style
We've yet to actually test this dock — unlike the rest of our picks — but we're excited to. There are very few Quest 3 charging docks, and they're all on the expensive side. This BoboVR dock comes with extendable silicone straps for the controllers and can fit the controllers despite the extra silicone; the dock charges the Quest 3 and has a slot for the extra B100 battery pack that slots into our top pick, the M3 Pro head strap.
Swing away
Folks who love VR golf games should seriously consider a golf club accessory. for the more natural swing and the immersion. The Yoges Quest 3 golf club features an adjustable length that helps better distribute the weight than other clubs. We also really liked the HelloReal club for its handle-mounted trigger for grip-to-putt and swinging, but it seems to be out of stock.
Made for Meta
I tested the Roto VR Explorer and was blown away by how it improved the immersion. You attach a puck to the headset that makes your whole body turn when you turn your head, completely eliminating the nausea you experience when smooth-turning. It also adds some impressive haptics, a Quest 3 charging port, and other premium perks (for a premium price), while keeping you very comfortable.
Get the top Black Friday deals right in your inbox: Sign up now!
Receive the hottest deals and product recommendations alongside the biggest tech news from the Android Central team straight to your inbox!
- Michael L HicksSenior Editor, Wearables & AR/VR
