Best phone tripod 2025
Tripods can be game-changers in mobile photography.
The best phone tripod isn't just for DSLR and mirrorless cameras. Tripods can also play a pivotal role in mobile photography. Some of the best tripods will even help you better capture scenes in the brightest or darkest conditions for any phone you attach to them. This guide will help you find the right fit for you so you can compose the most stunning images.
Sensyne's 10'' Ring Light with 50'' Extendable Tripod Stand offers the best traditional tripod functionality made for phones to shoot pictures with. if you're looking for smaller, more portable form factors, there are loads of excellent alternatives and they all are reasonably priced. You can even score a phone tripod with MagSafe compatibility.
Add a level of finesse to your mobile photography with these tripods
Best overall
Sensyne offers an extremely versatile range of budget-friendly tripods. The 10'' Ring Light with 50'' Extendable Tripod Stand is ideal for mobile phone users as it comes with a ring light, remote control, and adjustable stand that goes from 10 inches to 50 inches in a jiffy. For a few more dollars, you can get the RGB light version.
Best extra-long
If you need a really tall tripod for your photography, try the extra-long UBeesize 67" Phone Tripod & Selfie Stick for size. This 67-inch accessory doubles as a selfie stick, has a remote, has an adjustable height, and has a very stable clamp for your phone.
Best flexible
JOBY is a really famous name in the photography world. The brand makes superb camera accessories. You'll enjoy your experience with the GorillaPod Starter Kit, which comes with a flexible mini tripod and a handful of mounting accessories. The legs are so malleable, you can twist them around a tree branch and still get stable shots.
Best portable
This highly-rated selfie stick can be extended up to 63 inches long. It's a very compact tripod with a tiny remote. You can easily adjust the height. For such a tall phone tripod, it is extremely compact when folded up so it packs light and is ideal for vacations and trips.
Best MagSafe
It's expensive, but the andobil MagStick Selfie Stick Tripod is the ideal tripod for MagSafe lovers. All you need is a MagSafe phone case or adapter ring for Android and you can use this compact and convenient magnetic tripod cum selfie stick anywhere you go. Plus, it has a remote built-in.
Best budget
On a very tight budget? No problem! The tiny yet mighty Aureday Flexible Tripod is super affordable, coming in well below the $20 mark. You get flexible legs, a clamp, a remote control for long-distance shots, and three colors to choose from.
Make your phone's photos and videos look professional
Finding the right phone tripod really boils down to what it is you're trying to achieve. More seasoned mobile photographers will probably have figured that out going in, but sometimes, creative opportunity knocks when you least expect it. That's why this list is varied. The Sensyne 10'' Ring Light with 50'' Extendable Tripod Stand is the best option for most situations and with a wide range of phones.
And if you don't want the clamp anymore, you can always attach another. Even when closed, the tripod acts as a decent handheld stabilizer. It doesn't have flexible legs, or a Frankenstein-like rig to attach supporting gear, but it's well-made, dependable, and can work with many DSLR and mirrorless cameras in addition to your phone.
Good and supportive gear can always help take better photos, but you should look into learning some of the fundamentals of using your phone's camera first. You can level up your mobile photography game with a few simple tips and tricks, which we have compiled in a handy guide of sorts for beginners. It also helps to have the best camera app on your Android phone so you have all the right tools to capture world-class images.
Be an expert in 5 minutes
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
- Ted KritsonisContributor, Audio Reviewer
