Best phone cleaning kits 2023
We use our phones anywhere and everywhere, exposing them to filth, germs, bacteria, and even viruses. We take them from place to place, holding them in our hands, to our ears, and putting them in our bags or pockets. It's a good idea to properly clean and disinfect your device frequently to keep the grime and nastiness under control so those germs don't migrate from the phone to you.
Fortunately, here are some of the best phone cleaning kits that include everything from phone sanitizers, screen wipes and sprays, and also cleaning solutions that will help you and yours remain healthy.
Efficient cleaning made easy
Be gentle, please
Chances are, the part of your phone that requires the most frequent cleaning is the screen, and pre-moistened ZEISS Screen Wipes are the perfect way to get a streak-free clean without needing harsher chemicals. But the screen isn't the only part of the phone that should get a regular cleaning. It's also a good idea to consider deeper UV treatments every so often.
I also supplement these screen cleanings with deeper UV treatments in a device like the PhoneSoap 3 UV Sanitizer. This phone sanitizer will give your device a thorough clean, and charge it at the same time so you're ready to go for the day.
With the best phone cleaning kits, you want to avoid abrasives and harsh chemicals because abrasives can scratch the screen and chemicals can eat away at protective coatings. Alcohol and ammonia-free solutions are preferable when cleaning a phone, but if you want a cheap, easy solution, dilute isopropyl alcohol and water in a misting bottle. To disinfect your phone, just spray a microfiber cloth instead of the screen and use it sparingly.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
