Best phone armbands for running
Keep your phone safely with you as you jog.
When you're a dedicated runner, having the right accessories can make or break your workout experience. If you're searching for the best phone armband for running, we've got you covered. No matter what type of phone you have, you'll be able to find a product that offers the protection you need. While you're at it, check out our roundup of the best headphones for runners, too!
Staff Pick
Want an affordable armband that's made of premium-grade materials? This TRIBE Fitness armband is the perfect solution. Its no-slip design and weatherproof and water-resistant technology protects your phone from rain and sweat. There's also a reflective strip to ensure safe running at nighttime. It's truly one of the best phone armbands for running.
One size fits all
This water-resistant armband from Trianium is designed with a lot of sizes in mind. Not only can it accommodate arms up to 14 inches around, but it can also work with popular case brands like Otterbox and LifeProof. The stretch-resistant neoprene material easily bends, twists, and folds without becoming warped. You'll be protected against water and sweat, too.
Durable comfort
You don't want a flimsy armband that's going to slide around during your workout. The Armpocket Mega i-40 armband is crafted with memory foam padding that's resistant to slippage. The bamboo rayon backing is naturally moisture-wicking, so sweat will never be an issue. The interior storage can also hold keys, credit cards, and money.
Mount it and forget it
If you're tired of attempting to navigate your touchscreen through a film, you'll appreciate this unique option from LifeProof. You'll be able to mount your phone directly onto the LIFEACTÍV armband with a click, thanks to the innovative QuickMount technology. The sleek, low-profile design will never weigh you down during your runs.
Secure grip
When you're seeking an armband with a secure grip that won't bounce or slide around, the Tune Belt Armband is an excellent option. The clever design features no openings that touch the skin, so you always stay dry. It has a soft cushion that maintains a secure grip without feeling too tight. You can move freely during your run without worry.
Super lightweight
Perhaps you're looking for the least bulky option possible. If so, check out the E Tronic Edge phone armband for running. This lightweight sleeve is made of quick-drying nylon and spandex that's very breathable. It's available in numerous sizes and can accommodate any phone. It's large enough to store other items, like your keys, wallet, and so on.
Super flexible
Are you tired of phone armbands that are difficult to use? You'll love this 360-degree rotatable option from newppon. This is the best phone armband for running when you need maximum flexibility. You don't have to remove your phone case, either! The sure-grip design prevents your phone from slipping or dropping during workouts.
Finding the right phone armband for you
The right phone armband for you really depends on the design, the phone you own, and your comfort level. But with new updates to Android 12 and all the personalization that comes with it, along with many of the best Android phones you can buy, you'll love being able to take your phone with you. Pair it with one of the best headphones for runners and you'll be well on your way to tackling a 5 or 10K marathon in record time.
But even for your own personal daily morning, afternoon, or evening runs, having a good phone armband means you can track your routes via GPS, keep on top of progress in fitness apps, and listen to your favorite music to help you keep up the pace. And the phone won't get in the way of your form.
Courtney Lynch is a freelance writer at Android Central. She's obsessed with all things health, fitness, and music. At any given time, she can be found checking out the latest and greatest gadgets while simultaneously petting her dog and sipping iced coffee.
