Best Meta Quest 3 & 2 battery packs
These are the best Meta Quest battery packs and straps for the Quest 3 and Quest 2, both of which only last about 2 hours per play session without these accessories.
The best Meta Quest battery pack can add hours to your VR play sessions, keeping you from having to take a break right when the action really gets going.
A fully charged Oculus Quest 2 or Meta Quest 3 will give you about 2–3 hours of battery life; the Quest 3 is especially short-lived, thanks to its performance boost over the Quest 2. For anyone who enjoys longer VR sessions or shares their Quest with friends or family members, 2 hours isn't enough time.
Battery packs are some of the best accessories you can get for your Quest because they can double — or in some cases, even triple — the headset's battery life. We've tested dozens of different head straps, batteries, and other Meta Quest 3 accessories to try and find a solution to this Meta battery issue.
Here are some of the best battery packs and battery straps for the Meta Quest 3 or Oculus Quest 2!
All the best Meta Quest battery packs for Quest 2 and Quest 3
For the Quest 2 or Quest 3
BoboVR makes the M2 Pro for the Quest 2 and M3 Pro for the Quest 3, each of which adds supreme comfort to your VR headset and includes one hot-swappable magnetic battery pack that's also rechargeable. Buy as many packs as you need to keep going! Each 5,200mAh pack adds about 2 hours of game time to your Meta Quest.
Quest 3 and Quest 2
Already happy with your head strap and don't want to buy another one? Then Zyber has the perfect product for you! This 5,000mAh battery pack magnetically attaches to the side of your Quest 2 or 3 and adds several hours of playtime to your experience. Grab a second one and keep it charged so you can hot-swap them without interrupting your play session!
Quest 3 and Quest 2
While some Quest 2 owners don't mind storing a power bank in their pocket while playing, having to be mindful of a USB cable at all times can be a hassle. The NIRVANA VR Battery Pack is a cost-effective solution. It comes with a pouch that snaps directly onto the back of your Quest 2 headset. Best of all, the included 10,000mAh power bank provides up to a whopping eight hours of uninterrupted gameplay.
Quest 3 and Quest 2
Rather than being strapped to your headset, this nifty battery pack from AMVR is instead worn around your neck, creating a more comfortable experience for anyone who finds traditional battery packs too heavy on their head. Additionally, it can charge the Quest and Quest Pro headsets, as well as the Pico 4.
Quest 3 and Quest 2
This battery pack can uniquely be worn around the waist or crossbody over your shoulder, which helps redirect weight from your head or neck so you can move more freely while playing. The 10,000 mAh battery capacity means it can extend the VR experience anywhere from an extra 4 up to 9 hours. Plus, it can be used for other devices beyond just VR headsets.
Quest 2 only
If you're still rocking the Quest 2 and looking for an affordable way to extend battery life, this battery pack gives you a reasonable extra 2-4 hours of playtime via its 5,000 mAh battery. But it also has a useful IR light built in to help enhance gameplay in the dark. With adjustable brightness, your late-night or backyard game sessions will be better (and brighter) than ever.
Quest 3 only
Closing out our list, we'll focus more on Quest 3 battery straps instead of battery packs. The Kiwi Design strap doesn't let you swap in a new pack, but you still get 6,400mAh of extra battery capacity, good enough to double your Quest 3's meager 2-hour lifespan. Comfortable, balanced, and easily secured to your head size, the Kiwi Design strap is a great all-in-one option.
Quest 3 only
Another Quest 3 battery strap to consider, this Saqico model gives you an impressive 10,000mAh of battery capacity packed directly into the Elite-style strap with a knob for a secure fit and a hinge to help you find a comfortable angle. Like many battery straps, it's on the heavy side, but the extra security and play length make this a reasonable trade-off.
Alternative power bank options
When using a VR headset, it's best to use bespoke hardware. You'll get comfort enhancements and play like it was meant to be played. You can also use a regular old USB power bank but, keep in mind that having a battery in your pocket and a long cable running up to your headset can be awkward. Still, we'd love to recommend a few low-fi Quest power bank options to get you going.
Quest 2 only
KIWI Design makes a simple little product that attaches any battery pack you might already own below to your headset via adjustable velcro straps. This pack comes with that velcro strap, a small USB cable to connect your battery pack to the Quest 2, and a small adjustable zip tie to keep it in place. If you're planning to use a regular USB power bank and don't want it in your pocket, this is a pretty good alternative.
Big and beefy
The Anker PowerCore 10000 offers a lot of reliability and power and is a popular pick for powering mobile devices. It's high-speed and compact, so it's perfect for charging your Meta Quest. The Anker PowerCore 10000 even comes in a variety of cool colors that will zhush up your headset.
Powerhouse
The Anker PowerCore 20,100mAh is essentially a larger and more powerful version of the PowerCore 10000. It's a bit more expensive and bulkier, but it'll last much longer than its little sibling. It comes in great colors and can hold a charge for weeks.
What features to consider when buying a Meta Quest battery pack
The most important thing when choosing an external battery pack for the Meta Quest 3 or Oculus Quest 2 is that it should support at least 9V 2A (18W) for optimal performance. There are many batteries on the market with those stats, but there are many other things to consider, such as size and how long they will hold a charge. Still, connecting a battery pack can extend your gaming sessions in the best Quest 3 & 2 games without needing to seek out a wall charger every time you take a break.
The BoboVR M3 Pro for the Meta Quest 3 or BoboVR M2 Pro for the Quest 2 are the best way to add comfort to your play sessions and keep them going for longer with the ingenious magnetically detachable, hot-swappable and rechargeable battery packs. It's the most foolproof way to get longer battery life and not have to worry about a cord getting in the way.
Any of these power banks will let you stay in VR longer. Depending on your needs, some banks may be more suitable than others. Go with the largest battery capacity you can afford to get the most out of the extra charging abilities.
Be an expert in 5 minutes
- Nick RansbottomFreelance writer, VR/AR
- Michael L HicksSenior Editor, Wearables & AR/VR
This is Vivo's mixed reality headset
Google ignored Android XR at GDC 2025, and indie VR devs are concerned
