Best Oculus Quest 2 controller alternatives 2023
The Quest 2 surrounded by video game controllers
(Image credit: Nick Sutrich / Android Central)
The Oculus Touch controllers that come packed in with the Oculus Quest 2 are fantastic VR controllers. Although these controllers will have you covered for most games — especially ones that require lots of movement — some games just feel better with a traditional gamepad or something more specialized like a HOTAS flight stick. Or if you're looking to satisfy your inner hardcore PC gamer, you can even use a mouse and keyboard! No matter what you're looking for, these are the best Oculus Quest 2 controller alternatives for every situation.
These are the best Oculus Quest 2 controllers
The Xbox Series X Controller
(Image credit: Windows Central)
Xbox Core Controller
Best alternative controller
Reasons to buy
Excellent compatibility
Simple Bluetooth pairing
Super comfortable
Reasons to avoid
Might require an extra adapter for some PCs
The Xbox Core Controller has unbeatable compatibility and feel. This controller comes packed in with every Xbox Series X|S and features Bluetooth connectivity that perfectly pairs with your Oculus Quest 2 or gaming PC. Microsoft's Xbox controllers define how a great traditional controller should work and feel, and every game that supports a traditional controller works perfectly with this one.
While you can use most third-party Bluetooth controllers with your Quest, you're sure to experience some button mapping issues or other unexpected challenges. This isn't the case with the Xbox Controller. On top of its compatibility with your Quest, it's also easy to pair with a phone or gaming PC — although some gaming PCs might require the Xbox Wireless Adapter for Windows if they don't support Bluetooth connectivity.
The Xbox Core controller — and others like it — works best with sideloaded titles on Quest 2, while playing PC games with Quest can give you the perfect way to get a little personal space or to prevent younger eyes from catching a glimpse of M-rated games.
SteelSeries Stratus Duo
Best versatility
Reasons to buy
Works for consoles, PC, and mobile too
Comes with a USB wireless adapter
Reasons to avoid
Not quite as ergonomic as an Xbox controller
Some quality control issues have been reported
SteelSeries' controller costs less than the Xbox Core Controller, but it still boasts all the same buttons and great Bluetooth connectivity that'll work perfectly with your Quest 2 or gaming PC (or even your phone). SteelSeries even throws in a USB adapter for a PC, meaning you won't have to buy an extra one if your PC doesn't have Bluetooth — unlike the Xbox Core Controller — making this an even better value than the price initially suggests, especially if you're an avid PC gamer in the market for a new gamepad.
SteelSeries Stratus Duo controllers are similar to the original Xbox Controller S in some ways, but feature the parallel dual joystick placement you'd expect from a PlayStation controller and a more traditional cross-shaped D-pad. If you prefer the stick alignment on a DuelSense or DualShock controller or just want to save some dough, SteelSeries is a fantastic choice, for the best PC VR games and any other PC or mobile games you want to play.
Thrustmaster T1.6000M
(Image credit: Thrustmaster)
Thrustmaster T.16000M FCS HOTAS
Best HOTAS
Reasons to buy
Separate throttle and stick for better ergonomics
Solid construction
Lots of buttons
Reasons to avoid
No wireless option
Expensive
Needs to be plugged into a PC
If you've played Star Wars Squadrons or VTOL VR using your gaming PC and an Oculus Quest 2, you'll know it's challenging to precisely maneuver your ship in space using a joystick on a controller. What better way to put yourself inside the cockpit of an X-Wing than to have your very own flight stick and thrust? A hands-on throttle-and-stick (or HOTAS) is the absolute best way to up the immersion of piloting and dogfighting games that also give a far greater level of control over your movements.
Right now, no HOTAS pairs directly with Quest 2. Thankfully there aren't any native Quest 2 games that would require one, so if you pick up this HOTAS, you'll need to have it plugged into your gaming PC, where you'll be playing PC VR games with Quest 2.
The Thrustmaster T.16000M FCS HOTAS is a great value that separates the throttle from the stick, which allows for more ergonomic play. If you really want to go all-out, you can also grab an upgraded version on the Amazon page listing with separate pedals.
A person playing a game on the thrustmaster HOTAS
Thrustmaster T-Flight Hotas X Flight Stick
Best Value HOTAS
Reasons to buy
More affordable than many HOTAS
Single-body design keeps things simple
Quality construction
Reasons to avoid
No wireless option
Needs a PC to plug into
Sometimes, you just want a simple setup that isn't going to cost a lot of money. In that case, the Thrustmaster T-Flight HOTAS x Flight Stick may just be the perfect product. It retails for less than the Thrustmaster T.16000M and features everything in one plastic-molded body. That's the flight stick and thrust together in one package with just a single, easy-to-plug-in cable.
Like any HOTAS, remember that you'll only be able to use this by plugging it into a gaming PC and playing PC VR games with Quest 2. This will not plugin to or pair with your Quest 2, so it's important to know that before going all in. Two of the most popular games to use a HOTAS with are Star Wars Squadrons and Microsoft Flight Simulator, but you'll find there are plenty of VR-ready titles that support these incredibly immersive controllers.
A man wearing the Quest 2 holds an Apple Magic Keyboard
Best keyboard for VR
Reasons to buy
Works with Quest passthrough
Great key feel
Quiet keystrokes
Reasons to avoid
Not fully compatible with Windows
Not very ergonomic
Doesn't have the full set of keys
Did you know you can use a mouse and keyboard with the Quest 2? The Meta team's always adding more and more keyboards and mice to the list of supported devices with each Quest update. The Apple Magic Keyboard and some of Logitech's keyboards are supported and visible in VR via passthrough, so you can see the keys on your desk while in virtual reality. Logitech makes great keyboards, but its Quest-supported offerings tend to sell out pretty quickly, whereas Apple's popular, minimalist keyboard isn't going anywhere.
Sure, it's not technically a controller, but it's worth mentioning here because you can use it with Quest 2 apps like Horizon Workrooms and Virtual Desktop. Meta's been pushing the Quest as a "work" device, but you can still use a keyboard casually for chatting with friends on Messenger or for playing Steam games with keyboard controls since you can play non-VR games in-headset if you want!
A man wears the Meta Quest 2 with hand tracking enabled
(Image credit: Future)
Your hands
No controller needed
Reasons to buy
Nothing to buy
Don't need to charge
Super immersive
Reasons to avoid
Tracking isn't always reliable
Need to make sure you have bright lighting in a room
Limited number of experiences
You might laugh at this one, but, truly, using your hands in VR is a sublime experience — when it works, that is. After all, there's no controller more precise than your own fingers. In ideal conditions, the Oculus Quest and Oculus Quest 2 can track hands in VR space thanks to the four cameras positioned outside the headset. Hand tracking is best used for navigating the menus and official Oculus entertainment apps. However, the best hand-tracking games for Quest 2 will give you a uniquely immersive experience, even if there are only a few games that support the feature.
While hand tracking is obviously free and provides the most immersive way to interact with things in VR, there are a few things to consider. First off, you'll want to make sure you're in a brightly lit room so the cameras can see your hands. Second, know that hand tracking isn't the most accurate thing in the world, and you'll likely come across several situations where the Quest 2 has a hard time understanding what you want to do.
Hand tracking is still in its infancy in VR. In fact, it's turned off by default on new Quest devices, so if you're OK with a bit of jankiness, give hand tracking a shot. If, for no other reason, it's a fun way to see how the future of VR could look once tracking improves in future headsets.
Bottom line
The Oculus Quest 2 was made to be played out of the box without anything else to set up or worry about, but the right accessories can take even the best VR experience even higher. A reliable classic controller like the Xbox Core Controller will make it both fun and easy to play VR games that don't have the motion control support we've come to expect from VR titles today. You'll also find that these are a great way to play classic games via emulators — which can be sideloaded onto Quest — or when playing traditional games on a giant virtual monitor with software like Virtual Desktop.
A good HOTAS is a must for anyone interested in flight sims and dogfighting games. They'll help transport you into the cockpit of an aircraft or your favorite Star Wars ship. Just remember that these all require a gaming PC to plug into, and all games that support them will be running on a gaming PC.
Lastly are the hands-only experiences powered by the four cameras on the front of an Oculus Quest or Oculus Quest 2. Oddly enough, your hands can actually become controllers within the Quest's menus and any supported titles, meaning you won't even need to remember to grab new batteries for those controllers to get a uniquely immersive VR experience.
Nicholas Sutrich
Senior Content Producer — Smartphones & VR
Nick started with DOS and NES and uses those fond memories of floppy disks and cartridges to fuel his opinions on modern tech. Whether it's VR, smart home gadgets, or something else that beeps and boops, he's been writing about it since 2011. Reach him on Twitter or Instagram @Gwanatu
With contributions from
Read more
Comparing the Meta Quest 3S vs. Quest 3
Best VR headsets 2025
Best Meta Quest 3 accessories with the headset
Best Meta Quest 3 & 3S accessories 2025
"Best Meta Quest games" text next to a Meta Quest 3 headset
Best Meta Quest 2 and Quest 3 games
Playing Wall Town Wonders in mixed reality on a Meta Quest 3S
Best Link Cable alternatives for Meta Quest in 2025
A screenshot from a graveyard in House of Da Vinci VR on a Meta Quest 3
Already beat Batman? These are the next Meta Quest games you should play
A JPG photo of Nicholas Sutrich wearing a Meta Quest 3S, taken with a Vivo X100 Pro
Meta Quest 3S: Specs and everything you need to know
Latest in Virtual Reality
Vivo Vision Discovery Edition design reveal
This is Vivo's mixed reality headset
Samsung Project Moohan on display
Google ignored Android XR at GDC 2025, and indie VR devs are concerned
A panel of VR experts on stage at GDC 2025, discussing the "VR gaming visibility crisis."
Quest developers are joining forces to solve the 'VR visibility crisis'
A mockup of a mixed reality ornate ballroom with a Meta Quest 3. Ballroom made with Adobe AI
This new Meta Quest v74 feature is set to revolutionize immersive experiences
A promo image of the Meta Quest 3 on a grid background surrounded by eight bestselling VR titles in 2024, including Gorilla Tag and Batman: Arkham Shadow.
Meta's head of Oculus Publishing debunked Quest Store 'theories' and hinted at their Quest 4 audience at GDC
An official Gorilla Tag screenshot made to look like a "monke" is wearing a pink support headset
Gorilla Tag finally fixed its voice moderation problem
Latest in Buying-guide
Photos of the Nothing Phone 3a series.
Nothing Phone 3a vs. Moto G Power 2025: It all depends on where you live
Apple iPhone 16e review against colorful background
iPhone 16e vs. OnePlus 13R: Quantity versus quality
The Iris Google Pixel 9a (left), Bay Google Pixel 8a (center), and Obsidian Google Pixel 7a (right) on a desk, the photo showcasing their different designs.
Should you upgrade to the Pixel 9a?
The Obsidian Google Pixel 9a held in hand above a houseplant.
Google Pixel 9a vs. OnePlus 13R: Budget battle
Does the Google Pixel 9a support Qi2 wireless charging?
The Iris Google Pixel 9a held in hand, the photo taken downards to emphasize its color and size.
Google Pixel 9a vs. Nothing Phone 3a Pro: The sensible and enthusiast picks
