Best Motorola edge screen protectors 2025
The Motorola Edge (2021) brings gaming phone-level high refresh rates to the mid-range segment. Meanwhile, the Edge+ (2022) makes an attempt to reach for the stars with its 6.7-inch pOLED display, maintaining the Edge (2021)'s sublime 144Hz refresh rate. Whether its the pricier Edge+ or the more affordable Edge, you would want to take care of your Motorola phone's beautiful screen. To help you preserve your beloved phone's smooth display, we have rounded up the best Motorola Edge screen protectors for you.
Best Motorola edge (2021) screen protectors
Best Motorola Edge+ (2022) screen protectors
Best Motorola Edge (2022) screen protectors
Add layers of security to your Motorola Edge
To increase security, a screen protector should be the first thing you buy for your phone, followed by a case for your Motorola Edge. The majority of your hard-earned coin goes towards the cost of the display when buying a phone, so make sure you safeguard it. If you didn't get a protective film for your Moto Edge from the get-go, we've got you covered.
Our top pick for your 6.8-inch Motorola Edge (2021) is the Supershieldz Tempered Glass Screen Protector. It comes in a set of two and offers high clarity, reliable durability, and scratch-resistance. You get bang for your buck and a couple of extra screen protectors for emergencies. If you're on the prowl for a more premium product, the SaharaCase ZeroDamage Screen Protector serves as the best alternative. It costs a tad more, but you'll go to sleep comfortably at night knowing that your Motorola Edge is secured by top-tier tempered glass.
On the other hand, the best Motorola Edge+ (2022) screen protector is none other than the first-party option from Motorola itself. It fits your 6.7-inch Edge+ perfectly, touts 9H hardness, and resists dirty fingerprint marks easily thanks to the oleophobic coating. For one piece, it is quite pricey. If you're looking to get some value for your coin, we suggest the TQLGY Camera Lens Tempered Glass 3 Pack for a glass option, and the Supershieldz PET Screen Protector 6 Pack for a protective film.
The Motorola Edge (2022) is the smallest and newest of the trio. At the moment, there's barely anything available on the market. Fortunately, what you can buy is a stellar protector for your spanking new Edge (2022)'s 6.6-inch OLED display. Supershieldz offers a 2-pack and a 3-pack of its Tempered Glass screen guards. Each sheet of Supershieldz Tempered Glass repels dust and liquids, resists scratches, and puts up a good fight defending your Motorola phone's OLED panel.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
