Best Amazon Fire tablet 2025
If you're looking for the best Android tablet for casual use like light gaming, surfing the web, or something to keep your kids entertained on a road trip, the best Amazon Fire tablets are what you should be looking at. There's essentially something for everyone across Amazon's lineup of Fire tablets, ranging from the ultra-budget Fire 7 and going up to the more premium Fire Max 11. Plus, there are also Kids editions which come in bright colors and have added protection.
Photo of Andrew Myrick, Senior Editor of Android Central
Andrew Myrick
Andrew Myrick is a senior editor at Android Central. In between figuring out ways to put retro emulators on everything, Andrew thoroughly enjoys exploring what's possible with Android tablets. He's constantly looking for new and different ways to use tablets, such as replacing his laptop or turning tablets into smart home dashboards.
At a glance
Best overall
Amazon Fire HD 8 (2024) in hand
(Image credit: Amazon)
Best overall
Specifications
Display: 8-inches, 1280x800 (189ppi)
Processor: Hexa-core 2.0 GHz
Memory: 3GB/ 4GB RAM, 32GB / 64GB expandable storage
Cameras: 2 MP front; 5MP rear-facing
Battery: Up to 13 hours
Dimensions: 7.94 x 5.40 x 0.37-inches, 337 grams
Colors: Black, Emerald, Hibiscus
Reasons to buy
More RAM than previous generation
Expandable storage
Fast-charge capable through USB-C port
Hands-free Alexa
Reasons to avoid
Fire HD 10 has a higher-res screen
Google apps not included
The Amazon Fire HD 8 (2024) is physically identical to the older Fire HD 8, but with better internals. It comes with 3GB or 4GB of RAM depending on the storage, a 5MP rear camera, and newer colors. It still has the same lightweight design and compact dimensions that made the previous model so great.
It's the lowest-priced Fire device you can get with a 1280x800 resolution display. The base model comes with 32GB of storage, but you can quickly and cheaply add to that with a microSD card and expand up to 1TB. With up to 13 hours of battery life, you'll have plenty of juice to watch several movies or play games on the go.
The device features Dolby Atmos support through its dual stereo speakers and comes with a headphone jack to enjoy your music or videos. Unfortunately, you won't get access to Google apps, but the Amazon app store has better offerings than it used to.
What sets this new model apart is the GenAI features that come built-in. Writing Assist helps you draft a complex email with the right tone that you require, while Webpage Summaries does exactly what it sounds like. There's also a Wallpaper Creator which lets you generate a new image based on text prompts that you input. It's worth noting that these AI features will be rolled out to older Fire tablets too that are compatible.
Best for work and play
Amazon Fire Max 11 Device Dashboard
(Image credit: Andrew Myrick / Android Central)
Specifications
Display: 11-inches, 2000x1200 (213 ppi)
Processor: Octa-core 2.2 GHz
Memory: 4GB RAM, 64GB/128GB expandable storage
Cameras: 8MP front and rear-facing
Battery: Up to 14 hours
Dimensions: 10.2 x 6.44 x 0.3 inches
Reasons to buy
Beautiful 11-inch display
Biggest Fire Tablet screen
Compatible with USI 2.0 stylus pens
Better performance than expected
14 hours of battery life
Reasons to avoid
Play Store is only available if you side-load
Keyboard, case, and stylus are all sold separately
Only 60Hz refresh rate
In a world where Android tablets are largely considered inferior to the iPad, Amazon decided to shake things up with the release of the Fire Max 11. As the name implies, this Fire Tablet sports an 11-inch display with a 2000x1200 resolution.
Powering the device is the MediaTek MTK8188J octa-core processor paired with 4GB of RAM and up to 128GB of expandable storage. On the front and back, you'll find 8MP cameras, which will be just fine for participating in video calls or snapping quick pictures.
Where the Amazon Fire Max 11 really stands out is in the plethora of productivity-focused accessories. Alongside this new tablet, Amazon also released a detachable keyboard case and a USI 2.0 stylus pen. The former lets you prop up the Fire Max 11 anywhere, while the latter lets you jot down notes and even works with many of the best Chromebooks.
Unfortunately for some, at least, you're still stuck without the Play Store or Google Play Services, instead needing to rely on the Amazon App Store. On the bright side, it's pretty easy to sideload the Play Store onto the Amazon Fire Max 11, so that can be remedied fairly quickly.
Something that can't be remedied is the display, which only comes in with a 60Hz refresh rate. We would have liked to see at least a 90Hz panel if not 120Hz, but that just gives Amazon some room for improvement if it ends up releasing a successor.
Best tablet for sharing
Amazon Fire HD 10 Tablet
3. Amazon Fire HD 10 (2023)
Specifications
Display: 10.1-inches, 1920x1200 (224 ppi)
Processor: octa-core 2.0 GHz
Memory: 3GB RAM, 32GB / 64GB expandable storage
Cameras: 5MP front-facing and 5MP rear-facing
Battery: Up to 12 hours
Dimensions: 9.73 x 6.53 x 0.36 inches
Colors: Black, Denim, Lavender, Olive
Reasons to buy
Full HD display
Dolby Atmos and dual stereo speakers
More storage than competitors
13 hours of battery
Reasons to avoid
Cameras are low resolution for a "high-end" device
Highest priced Fire Tablet, non-Kids Edition
A little heavy
If you want the most immersive video and gaming experience on a Fire Tablet, you want a Fire HD 10. We know it's the most expensive Fire, but it's still darn affordable. Try finding another Android tablet or iPad of this size at anywhere close to this price.
The Amazon Fire HD 10 (2023) is a large Amazon tablet with a full HD 1080p display, coming in at 1920x1200 resolution. It offers up to 13 hours of battery life, including video watching, web browsing, and music listening — which we discovered was accurate through our hands-on testing. The Fire HD 10 also comes with Dolby Atmos, dual stereo speakers, and a headphone jack. You get a 5MP front and rear camera with 1080p video recording.
As its size would suggest, the Fire HD 10 comes with more storage (up to 64GB) that is expandable up to 512GB, and it has the best processor in the Fire Tablet line. You can use that storage and processing speed to watch hours of movies and TV shows, and playing mobile games on that full HD screen is a delight.
While the 2021 edition of the Amazon Fire HD 10 was a bit heavy for some at just over a pound (16.4oz), the latest version is a bit lighter at 15.29 ounces. It's a fantastic device for reading books, newspapers, magazines, or even websites — particularly if you need or want to enable a larger font because there's just so much more screen space to view your content.
Best value tablet
Amazon Fire 7 (2022) playing Shrek on desk
Best value tablet
Specifications
Display: 7-inches, 1024x600 (171 ppi)
Processor: Quad-core 2.0 GHz
Memory: 2GB RAM, 16GB / 32GB expandable storage
Cameras: 2 MP front and rear-facing cameras
Battery: Up to 10 hours
Dimensions: 7.11 x 4.63 x 0.38 inches
Colors: Black, Denim, Rose
Reasons to buy
The lowest point of entry into the Fire ecosystem
Expandable microSD storage
Easy hands-free Alexa
Reasons to avoid
Not HD resolution
Lower-quality mono speaker
No protective case included
Every excellent product line has its entry point, and for the Fire tablets, that's the Fire 7, which we loved when we reviewed it. This version is the perfect portable companion for anyone who wants a low-cost tablet to watch their favorite shows, play games, read new Kindle books, and even occasionally surf the web or check Facebook. As with the other Fire tablets, this device comes with 2MP front and rear cameras and a 720p HD video camera, so you can still snap decent shots and video chat to your heart's content.
This would be a great option if you're looking to get an affordable family tablet to share with your kids. With the savings you'll get on this device, you can easily afford to pick up a protective case (maybe one that isn't neon pink or yellow). You can also add Amazon Kids+ to this or any other Fire tablet whenever you want.
You can still access all of your favorite content from Amazon and other services through this device. Even though it's not HD resolution, the screen looks good enough for most use cases. The battery life is decent, and you can add to its internal storage with a microSD card. The Amazon Fire 7 is already cheap, but you can often find it on special for even less, making this practically an impulse buy.
Best large tablet for kids
Amazon Fire HD 10 Kids and Fire HD 10 Kids Pro on table
Specifications
Processor: Octa-core 2.0 GHz
Memory: 3GB RAM, 32GB expandable storage
Cameras: 2 MP front-facing and 5MP rear-facing cameras
Dimensions: 7.4 x 10.1 x 0.7 inches
Colors: Happy Day, Mint, Nebula
Reasons to buy
HD Display
Expandable storage
One year of Amazon Kids+ included
Two-year warranty included
Kid-proof case with built-in stand included
Reasons to avoid
Limited internal storage
Significantly more expensive than "regular" Fire HD 8 Tablet
Some may object to this pick based on the price alone. The Amazon Fire HD 10 Kids Pro (2023) is significantly more expensive than the Fire HD 10 Tablet, even though they are essentially the same device. So why is this so? It's about all of the extras, which add up to a good value, as we found through our hands-on testing.
Amazon's Kids Edition Fire tablets all come with a kid-proof case with a built-in stand to protect it from inevitable accidents. In the case (pun intended) of the Fire HD 10 Kids Pro, you can get one with a Happy Days, Nebula, or Mint finish. In addition to the case, Amazon throws in a two-year worry-free guarantee, so you can send the device back at any time if it gets damaged, and Amazon will send you a new one.
Just as important as physical device security is digital peace of mind. The Fire HD 10 Kids Pro comes with parental controls that allow you to decide what your child can and cannot do on-device. For example, it's easy to set screen time limits, curfews, or limit content. Alexa and in-app purchasing are disabled by default. The device also comes with one year of Amazon Kids+, which gives you access to 20,000 apps, books, videos, games, audiobooks, as well as educational content from PBS Kids, Nickelodeon, Disney, and more.
Back to the specs, this tablet features 32GB of storage, with the option to expand up to 1TB via the microSD card slot. Of course, you also get unlimited cloud storage for any content purchased through Amazon. The Amazon Fire HD 10 Kids Pro (2023) can get up to 13 hours of battery life depending on usage, and it features dual stereo speakers and, blissfully, a headphone jack. There are also 2MP front and 5MP rear-facing cameras and a 720p video camera for those times when you want to have the kids chat with the grandparents. It's really one of the best Amazon Fire tablets for kids.
Best small tablet for kids
Amazon Fire HD 8 Kids Pro (2022)
(Image credit: Chris Wedel/Android Central)
Specifications
Display: 8-inches, 1280x800 (189 ppi)
Memory: 3GB or 4GB RAM, 32GB expandable storage
Cameras: 2 MP front and 5MP rear-facing cameras
Dimensions: 8.3 x 6.4 x 0.7-inches, 509 grams (with Kid-Friendly case)
Colors: Hello Teal, Marvel Avengers, Discovery, Jungle Cat
Reasons to buy
Includes six months or one-year subscription to Amazon Kids+
Protective case included
Two-year worry-free guarantee
Easy-to-use parental controls
Two storage options
Reasons to avoid
Slow charging speeds
While the Fire HD 10 Kids Pro is our pick for best Fire Tablet for kids, the Amazon Fire HD 8 Kids Pro (2024) is a close runner-up. It’s definitely a better option if you’re worried about portability. As you would expect, the Fire HD 8 Kids Pro still includes Amazon’s Kid-Friendly Case, along with a six-month or one-year subscription to Amazon Kids+ and more. Amazon also includes a “two-year worry-free guarantee,” so if disaster strikes, the company will replace the tablet for free.
The new refresh gets all the new features of the Fire HD 8 (2024) like more RAM, a 5MP rear camera, and a 64GB storage option. Battery life is also improved over the Fire HD 10 Kids Pro, as the Amazon Fire HD 8 Kids Pro lasts for up to 13 hours on a single charge.
With access to all the different content offered by Amazon Kids+, you’ll enjoy the 32GB of base storage and the included microSD card slot. Plus, this tablet offers the ability to use up to a 1TB microSD card, giving you more than enough space for all the movies and TV shows you can think of.
Under the hood, you get a hexa-core 2.0GHz CPU paired with 3GB or 4GB of RAM for solid performance overall. Its smaller display has a 1280x800 resolution allowing the tablet to easily make it to the end of the day on a single charge. And despite the upgraded USB-C port, you’ll still be waiting for a few hours before it will be juiced back up to 100%.
How to choose
The lineup of Amazon Fire tablets has never been so complete, and we can understand why these are among the best Android tablets on the market. They offer a great entertainment experience with industry-leading parental controls and child content options, as well as access to Alexa and Amazon's connected home ecosystem, at a fantastic value.
When looking at Fire tablets, we feel that the Fire HD 8 (2024) is the best choice for most people. It has an impressive HD screen, expandable storage, and hands-free Alexa. For the price, you can feel comfortable picking up two or three of these for less than the cost of an iPad, and you can easily share them with your family members if you choose.
How to decide which Fire tablet to get
Show Mode on Amazon Fire HD 8 (2022)
If you've already decided to grab an Amazon Fire tablet, which count among the best cheap Android tablets, then you've already conquered half the battle. The other half comes down to figuring out what it is that you plan to use the tablet for.
Every one of the tablets that you see listed here has been through a series of tests during our reviews. It's a similar process to the one that we use for testing the best Android phones and is even more similar to the way that we test Chromebooks.
Different considerations are made, such as things like design and durability, battery life, what features are available, and more. You won't find the Play Store out of the box. But we still put these tablets through their paces and leverage what's available in the Amazon Appstore.
Those who are looking at a Kindle-type replacement would be better suited with the Fire 7 or the Fire HD 8 thanks to their lightweight designs and portability. There's enough storage onboard for most of your books, but both of these tablets also feature expandable storage, allowing you to throw in one of the best microSD cards for even more. The latest Fire HD 8 also gets most of the features from the Plus model like hands-free Alexa, so you can check your smart doorbell without reaching for your phone.
Then there's the Fire HD 10 (2023), which is one of the largest tablets in Amazon's lineup. It's an upgraded version of the original from 2021 with more power and a lighter design. As for the best Fire tablet for kids, you get pretty much all of the same benefits as the non-kids counterparts, just with a few extras. These include things like a bundled case and up to a one-year subscription to Amazon Kids+. But just as a reminder, these sport a different interface compared to the "regular" versions.
What is an Amazon Fire Tablet?
Amazon Fire Max 11 angled on deskl
When you're comparing the best Fire tablets to the best Android tablets, you might be wondering what the real difference is between the two. While all of the tablets on this list are technically running a version of Android, it's not the same flavor or experience that you'll find on something like the Google Pixel Tablet or the beefier Galaxy Tab S11 Ultra.
That's because Amazon Fire Tablets use a modified version, or fork, of Android known as Fire OS. Instead of being able to sign in with your Google account and have access to the Play Store, Fire Tablets require you to sign in with your Amazon account. And when it comes to app downloads, you have to use Amazon's Appstore, not the Google Play Store.
There are quite a few apps that are available on both platforms, but if you've paid for something like Minecraft on the Play Store, that purchase won't transfer over to the Amazon Appstore because it's a separate entity entirely.
Samsung Galaxy Z Fold 7 vs. Honor Magic V5 on Android Central
(Image credit: Apoorva Bhardwaj / Android Central)
As for the interface, there's nowhere near as much customization as you might expect. This is because Amazon is trying to give you quick and easy access to all of its different services and outlets. It's why you'll see a list of Kindle books or Audible audiobooks you've purchased, or you'll see an ad for the latest show to arrive on Prime Video.
There are ways to still access the Play Store on Fire Tablets, making it possible to get rid of Amazon's convoluted interface with the help of a third-party Android launcher. But for most people, Amazon's Fire interface is just going to be what the doctor ordered. If you're entrenched in the Amazon ecosystem, all of your digital purchases are right at your fingertips.
Andrew Myrick
Senior Editor — Smartphones (North America), Chromebooks & Tablets
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
With contributions from
