Best Oculus Quest 2 controller alternatives 2023
For when the Oculus Touch controllers aren't the right fit for the game you're playing.
The Oculus Touch controllers that come packed in with the Oculus Quest 2 are fantastic VR controllers. Although these controllers will have you covered for most games — especially ones that require lots of movement — some games just feel better with a traditional gamepad or something more specialized like a HOTAS flight stick. Or if you're looking to satisfy your inner hardcore PC gamer, you can even use a mouse and keyboard! No matter what you're looking for, these are the best Oculus Quest 2 controller alternatives for every situation.
These are the best Oculus Quest 2 controllers
Xbox Core Controller
Reasons to buy
Reasons to avoid
The Xbox Core Controller has unbeatable compatibility and feel. This controller comes packed in with every Xbox Series X|S and features Bluetooth connectivity that perfectly pairs with your Oculus Quest 2 or gaming PC. Microsoft's Xbox controllers define how a great traditional controller should work and feel, and every game that supports a traditional controller works perfectly with this one.
While you can use most third-party Bluetooth controllers with your Quest, you're sure to experience some button mapping issues or other unexpected challenges. This isn't the case with the Xbox Controller. On top of its compatibility with your Quest, it's also easy to pair with a phone or gaming PC — although some gaming PCs might require the Xbox Wireless Adapter for Windows if they don't support Bluetooth connectivity.
The Xbox Core controller — and others like it — works best with sideloaded titles on Quest 2, while playing PC games with Quest can give you the perfect way to get a little personal space or to prevent younger eyes from catching a glimpse of M-rated games.
SteelSeries Stratus Duo
Reasons to buy
Reasons to avoid
SteelSeries' controller costs less than the Xbox Core Controller, but it still boasts all the same buttons and great Bluetooth connectivity that'll work perfectly with your Quest 2 or gaming PC (or even your phone). SteelSeries even throws in a USB adapter for a PC, meaning you won't have to buy an extra one if your PC doesn't have Bluetooth — unlike the Xbox Core Controller — making this an even better value than the price initially suggests, especially if you're an avid PC gamer in the market for a new gamepad.
SteelSeries Stratus Duo controllers are similar to the original Xbox Controller S in some ways, but feature the parallel dual joystick placement you'd expect from a PlayStation controller and a more traditional cross-shaped D-pad. If you prefer the stick alignment on a DuelSense or DualShock controller or just want to save some dough, SteelSeries is a fantastic choice, for the best PC VR games and any other PC or mobile games you want to play.
Thrustmaster T.16000M FCS HOTAS
Reasons to buy
Reasons to avoid
If you've played Star Wars Squadrons or VTOL VR using your gaming PC and an Oculus Quest 2, you'll know it's challenging to precisely maneuver your ship in space using a joystick on a controller. What better way to put yourself inside the cockpit of an X-Wing than to have your very own flight stick and thrust? A hands-on throttle-and-stick (or HOTAS) is the absolute best way to up the immersion of piloting and dogfighting games that also give a far greater level of control over your movements.
Right now, no HOTAS pairs directly with Quest 2. Thankfully there aren't any native Quest 2 games that would require one, so if you pick up this HOTAS, you'll need to have it plugged into your gaming PC, where you'll be playing PC VR games with Quest 2.
The Thrustmaster T.16000M FCS HOTAS is a great value that separates the throttle from the stick, which allows for more ergonomic play. If you really want to go all-out, you can also grab an upgraded version on the Amazon page listing with separate pedals.
Thrustmaster T-Flight Hotas X Flight Stick
Reasons to buy
Reasons to avoid
Sometimes, you just want a simple setup that isn't going to cost a lot of money. In that case, the Thrustmaster T-Flight HOTAS x Flight Stick may just be the perfect product. It retails for less than the Thrustmaster T.16000M and features everything in one plastic-molded body. That's the flight stick and thrust together in one package with just a single, easy-to-plug-in cable.
Like any HOTAS, remember that you'll only be able to use this by plugging it into a gaming PC and playing PC VR games with Quest 2. This will not plugin to or pair with your Quest 2, so it's important to know that before going all in. Two of the most popular games to use a HOTAS with are Star Wars Squadrons and Microsoft Flight Simulator, but you'll find there are plenty of VR-ready titles that support these incredibly immersive controllers.
Apple Magic Keyboard
Reasons to buy
Reasons to avoid
Did you know you can use a mouse and keyboard with the Quest 2? The Meta team's always adding more and more keyboards and mice to the list of supported devices with each Quest update. The Apple Magic Keyboard and some of Logitech's keyboards are supported and visible in VR via passthrough, so you can see the keys on your desk while in virtual reality. Logitech makes great keyboards, but its Quest-supported offerings tend to sell out pretty quickly, whereas Apple's popular, minimalist keyboard isn't going anywhere.
Sure, it's not technically a controller, but it's worth mentioning here because you can use it with Quest 2 apps like Horizon Workrooms and Virtual Desktop. Meta's been pushing the Quest as a "work" device, but you can still use a keyboard casually for chatting with friends on Messenger or for playing Steam games with keyboard controls since you can play non-VR games in-headset if you want!
Your hands
Reasons to buy
Reasons to avoid
You might laugh at this one, but, truly, using your hands in VR is a sublime experience — when it works, that is. After all, there's no controller more precise than your own fingers. In ideal conditions, the Oculus Quest and Oculus Quest 2 can track hands in VR space thanks to the four cameras positioned outside the headset. Hand tracking is best used for navigating the menus and official Oculus entertainment apps. However, the best hand-tracking games for Quest 2 will give you a uniquely immersive experience, even if there are only a few games that support the feature.
While hand tracking is obviously free and provides the most immersive way to interact with things in VR, there are a few things to consider. First off, you'll want to make sure you're in a brightly lit room so the cameras can see your hands. Second, know that hand tracking isn't the most accurate thing in the world, and you'll likely come across several situations where the Quest 2 has a hard time understanding what you want to do.
Hand tracking is still in its infancy in VR. In fact, it's turned off by default on new Quest devices, so if you're OK with a bit of jankiness, give hand tracking a shot. If, for no other reason, it's a fun way to see how the future of VR could look once tracking improves in future headsets.
Bottom line
The Oculus Quest 2 was made to be played out of the box without anything else to set up or worry about, but the right accessories can take even the best VR experience even higher. A reliable classic controller like the Xbox Core Controller will make it both fun and easy to play VR games that don't have the motion control support we've come to expect from VR titles today. You'll also find that these are a great way to play classic games via emulators — which can be sideloaded onto Quest — or when playing traditional games on a giant virtual monitor with software like Virtual Desktop.
A good HOTAS is a must for anyone interested in flight sims and dogfighting games. They'll help transport you into the cockpit of an aircraft or your favorite Star Wars ship. Just remember that these all require a gaming PC to plug into, and all games that support them will be running on a gaming PC.
Lastly are the hands-only experiences powered by the four cameras on the front of an Oculus Quest or Oculus Quest 2. Oddly enough, your hands can actually become controllers within the Quest's menus and any supported titles, meaning you won't even need to remember to grab new batteries for those controllers to get a uniquely immersive VR experience.
Be an expert in 5 minutes
- Charlie WacholzFreelance Writer
