Best portable chargers for Google Pixel in 2025
Keep your Pixel powered up for longer.
Google may be one of the leading OEMs for camera tech, AI features, and battery life, but even the best Pixel phones need an extra bit of juice from time to time. Whether you're using the powerful Pixel 9 Pro XL or still working with a Pixel 6a, these are the best portable power banks for Pixel devices.
Of course, not all power banks are made equal. When you're looking through the list, consider how much power you need and whether or not you need something portable or if the charger will be living on your desk permanently. Fortunately, no matter your needs, there are plenty of awesome options to explore.
These are the best portable chargers for Google Pixel
Best overall
Zendure's Supermini is a 10,000mAh power bank that comes in a fairly compact body, but don't let that small size fool you. This thing supports 20W charging over USB-C Power Delivery, which is all that your Google Pixel needs. The four LED lights allow you to keep tabs on the battery pack's charge level easily, and there are also a bunch of cool colors to choose from.
Best slim
Anker's products are well-known for offering amazing value for money, and the PowerCore Slim 10K is no exception. As you might've guessed by the name, it's a 10,000mAh power bank that features a fairly slim design. You get a PowerIQ USB-A port, as well as a USB-C PD port.
Best brick
Google no longer includes a charger in the box with its Pixels, so you need to buy one separately. Investing in a portable charger, like the UGREEN Uno Series Charger, is better. This tiny but fun-looking charger has GaN 100W Charging, charges up to four devices, and has eight levels of safety protection.
Best wireless charger
If you're in the market for a portable charger with wireless charging for your Google Pixel (and many other devices), look no further than iOttie's iON Wireless Go. This plane-friendly 10,000mAh battery pack supports wireless charging with the PPS spec needed to top up your Pixel at 10W or above.
Best high capacity
Among the best external battery packs out there, the INIU PowerNova 140W Power Bank has a 27,000mAh portable battery that's plenty for charging your Google Pixel and many other devices. It supports 140W charging and has one USB-A and two USB-C PD ports. The LED display shows the charging levels, making it easy to monitor the charge.
Best hybrid
InfinaCore has this weird yet wonderful concoction that can plug into any socket, function as a wireless power bank, and even top up your Pixel wirelessly. The P3 Pandora Portable Power Bank is a unique hybrid charger that's a jack-of-all charging needs.
Extend the life of your Google Pixel with these external battery packs
If you're still using the crowd-favorite Pixel 8a or have invested in the new Pixel 9 Pro, you'll need a portable charger. You need to ensure it can keep going all day and then some, especially when traveling. This is why we suggest getting one of the best Google Pixel portable chargers.
Our top vote goes to Zendure's Supermini, which offers 10,000mAh of portable power in a card-sized body that is easy to carry anywhere. Thanks to the funky colorways available, it even looks amazing.
Then there's Anker's PowerCore Slim 10K, which gives you two inputs (USB-C and USB-A) for easy recharging. The USB-A output port means it can work with just about any cable you might have lying around in your home. We also suggest looking at INIU's PowerNova 140W Power Bank, which includes a mighty 27,000mAh battery pack with two USB-C ports and a USB-A port for good measure.
Once you've picked the right external battery pack, pair it up with one of the best USB-C cables. The one Google gives you is okay, but it certainly doesn't last as long as a sturdy nylon braided wire.
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
