Best smart home devices 2025
Smart home devices are a dime a dozen these days and it doesn't cost much to get a smart home ecosystem up and running. Your Android phone can already act as a a hub for Google and Amazon IoT devices, so all you need is stable Wi-Fi in your house and you should be good to go. Some of the best smart home devices can be expensive, but there are plenty of wallet-friendly gadgets to choose from too.
Apart from the devices, smart home apps have gotten incredibly powerful. Take the Google Home app for instance, which apart from letting you control all your compatible devices from a single place, could soon even automate your house with its upcoming 'Vacation mode' feature. Here are some of the most popular smart home devices you should be using.
What are the best smart home devices?
You deserve the best smart home gadgets
Whether you live in the countryside or in the city, there are plenty of ways to make any home smarter. By simply adding smart lights, you can not only add convenience and lighting flexibility to your home, but you'll also save money. Apart from the popular brands like Govee, Philips, and the like, you should also check out products from Sonoff. It's a smart home brand you've probably not heard of but they have a good selection of DIY products like smart switches, plugs, motion sensors, and so on.
From a smart thermostat automatically adjusting the temperature when you aren't home to the ability to dim lights or turn off automatically when you aren't home, your home will use less electricity. By connecting these devices to Google Home or Amazon Alexa, you get a single app to manage all of your smart home items, and you'll gain voice control. Another option is Samsung SmartThings to manage your devices and pick up even more automation options. These are the best smart devices you can get regardless of where you are in your smart home journey.
Looking to dive deeper or maybe feeling a bit overwhelmed? The best way to start setting up your smart home ecosystem is to invest in some smart assistant technology. Check out our guides to the best smart speaker and best smart display to get started.
Patrick Farmer
eCommerce Editor
With contributions from
