I've tested dozens of wireless earbuds, and these are the pairs you should buy in 2025
Forget looking for a headphone jack on your phone. Those days are pretty much gone, so the only way to privately enjoy your favorite audio is to pick up one of the best wireless earbuds. Fortunately, I get to test dozens of earbuds and other audio equipment throughout the year, so I can tell you which pairs will work best with your Android phone whether you're looking to upgrade or buying your first-ever pair.
While you're checking out the list, ask yourself what you're looking for in a pair of earbuds. Will you mostly be using them to listen to music? What about phone calls? Solid options abound for use case and budget, so you just need to know where to look.
The Jabra Elite 10 Gen 2 currently lead the pack, thanks to a sophisticated balance of premium specs and bang for the buck, but they're not the only great option. If you're not sure whether earbuds are right for you, check out my guide to the best wireless headphones while you're in the neighborhood.
Ted Kritsonis head shot.
Ted Kritsonis
For 20+ years, Ted Kritsonis has been spending a lot of time testing out gadgets to help others make the best decision with their hard-earned money. When it comes down to audio devices, Ted's picks come from countless hours of listening for all the nuances that matter.
At a glance
Best overall
Jabra Elite 10 Gen 2 earbuds loose in front of open case.
(Image credit: Ted Kritsonis / Android Central)
Best wireless earbuds overall
Specifications
Water-resistance: IP68
Bud battery life: 8 hours
Case battery life: 30 hours
Case size: Small
Digital assistant: Google Assistant, Siri
Audio codecs: SBC, AAC
Speaker size: 10mm drivers
Wireless charging: Yes
Other features: HearThrough, equalizer, spatial audio
ANC?: Yes
Reasons to buy
Excellent audio quality
Improved ANC
Very durable and comfortable fit
Better spatial audio and head tracking
LE Audio through charging case
Solid app support
Reasons to avoid
No hi-res codec support
More expensive
Jabra's exit from consumer audio doesn't build confidence
The previous Elite 10 buds set the table as one of the best wireless earbuds worth the money, and the Gen 2 correct some missteps to deliver one of the best pairs you can buy. That's how we saw it in our review, as Jabra manages to maintain the same consistency in how it approaches both comfort and sound.
These earbuds don't change anything about the previous pair's sound signature, and you can still easily adjust it in the excellent Sound+ app available for Android and iOS. Better spatial audio this time around helps deliver a more respectable virtual surround sound effect. The biggest improvement comes with the ANC, which does significantly better at cutting out a broader scope of frequencies, including reducing wind noise during phone calls outside. Given these are still super comfortable and durable, they're also more than effective as workout earbuds too.
The charging case doubles as a playback conduit by way of Bluetooth LE Audio. Plug the included cable into any headphone jack and you can stream audio to the earbuds. Great for planes or anywhere Bluetooth isn't an option.
Battery life is okay at up to six hours per charge with ANC on, stretching that further to eight hours if you leave it off. The case nets an extra charges for an overall total between 24-32 hours. Charge the case itself via USB-C or Qi wireless charging, including a fast-charging option where five minutes can get you up to 60 minutes of playback. That's a complete, robust package right there!
Best upgrade pick
Sony WF-1000XM5 earbuds loose in front of case.
Best upgrade pick
Specifications
Water-resistance: IPX4
Case battery life: 24 hours
Case size: Medium
Assistant support: Google Assistant, Siri
Audio codecs: SBC, AAC, LDAC, LC3
Speaker size: 8mm drivers
Wireless charging: Qi
Other features: Ambient sound, equalizer, 360 Reality Audio
ANC?: Yes
Reasons to buy
Outstanding ANC performance
Stellar sound quality
Amazing battery life
Wireless charging case with USB-C
LDAC and 360 Audio support
Solid app support
Reasons to avoid
Touch volume controls need work
Smaller ears may not feel comfy
Expensive
At this point, ANC has become a standard feature in wireless earbuds, and we found the WF-1000XM5 are world-class by comparison in our review. That was already the case with the previous Sony WF-1000XM4, with the XM5 taking it even further to set the tone for everyone else.
Sony didn't have to play too much with the existing sound profile, choosing not to skew the default soundstage to push more bass. Instead, you get something more neutral to start off, leaving you plenty of room to customize it through the equalizer settings in the Headphones Connect app. Battery life is excellent as well, with up to eight hours alone (with ANC on) and an additional 24 hours with their charging case.
Sony continues to shave the earbuds and case down, and adding foam tips does wonders for passive noise isolation. Even with that, the WF-1000XM5 have an ambient sound mode that also performs well. And then there's 360 Reality Audio for listening to content with a spatial effect. If you've got the money to spend, the Sony WF-1000XM5 earbuds are definitely worth the splurge.
Best budget pick
EarFun Air Pro 4 wireless earbuds in black
(Image credit: Namerah Saud Fatmi / Android Central)
Best budget pick
Specifications
Water-resistance: IPX5
Bud battery life: 8 to 9 hours
Case battery life: 52 hours
Case size: Medium
Audio codecs: Qualcomm aptX adaptive, AAC, LDAC, SBC
Speaker size: 10mm
Other features: Ambient sound, equalizer, gaming mode, Auracast, hi-res audio, LDAC, Google Fast Pair
ANC?: Yes
Reasons to buy
Great audio quality
Adaptive ANC
Comfortable fit
Useful gaming mode
Solid app support and Google Fast Pair
Incredible battery life and wireless charging
Hi-res audio, LDAC, Bluetooth Auracast, Qualcomm aptX
Reasons to avoid
Only IPX5 splash-proof
EarFun makes earbuds at affordable price points, undercutting competitors in the same ballpark. The EarFun Air Pro 4 earbuds are no different, coming in way below what similar pairs generally sell for, which is great news for your wallet. based on what you get and the quality, it's hard to believe how affordable these earbuds are.
The value proposition here is just too good, bringing solid hi-res audio quality to anyone's ears, including excellent app support with an equalizer full of presets and custom adjustments. The stem design with curves is highly ergonomic and you get four extra ear tips in the box just in case.
Somehow, these below $100 earbuds offer Bluetooth Auracast thanks to the latest Bluetooth 5.4, LDAC, hi-res audio, Qualcomm aptX audio, Google Fast Pair, and wireless charging. That's an insanely wide range of premium features for a bargain right there. Not to mention, battery life is superb given the Air Pro 4 earbuds last up to 52 hours in total with the ANC off and including the case. Even with ANC on, you can easily get around 48 hours or two days' worth of juice.
Best for noise cancellation
Bose QuietComfort Ultra Earbuds open case on wooden table.
Best noise-canceling
Specifications
Bud battery life: 6 hours
Case battery life: 18 hours
Case size: Large
Audio codecs: SBC, AAC, aptX Adaptive
Speaker size: 9mm drivers
Wireless charging: No
ANC?: Yes (adjustable with 11 levels)
Reasons to buy
Superb sound quality
World-class ANC performance
Hi-res and spatial audio
Adjustable EQ
Comfortable fit
Multipoint support
Reasons to avoid
Wireless charging costs extra
Phone calls could be clearer
Pricey
We described the Bose QuietComfort Earbuds II as an elite pair of earbuds when it comes to proper ANC, and the QuietComfort Ultra Earbuds take things to another level. If you like to shut out the world completely, these buds are perfect for you.
Bose also chose to make some positive changes to the sound profile, maintaining the same neutral sound profile, only this time adding more features in the Bose app to tweak them. Not only that, but adding aptX Adaptive support brings in the kind of hi-res audio support that's been sorely lacking with the company's earbuds. Battery life is decent, though it varies with volume. You're more likely to get just above five hours and an additional 18 hours with the charging case. If you want wireless charging, though, you'll have to pay extra for it.
Without question, these will produce some of the best noise cancelation you'll find on any pair of earbuds. The ambient sound mode allows you to hear the outside world, removing the need to take off your earbuds if you'd like to hear what's going on around you. Just too bad phone calls aren't clearer.
Best for Samsung users
Samsung Galaxy Buds 3 Pro hands-on
Specifications
Water-resistance: IP57
Bud battery life: 7 hours
Case size: Small
Digital assistant: Bixby, Google Assistant, Siri
Audio codecs: SBC, AAC, SSC
Other features: HearThrough, 360 Audio, Voice Detect
ANC?: Yes
Reasons to buy
Improved ergonomics
Solid ANC
Perfect for Samsung’s ecosystem
Pretty rugged design
Good app support
Reasons to avoid
Still no true multipoint capability
So-so battery life
SSC codec hi-res playback limited to certain devices
Samsung chose to go with a different look — at least compared to its previous earbuds — by bringing stems into the overall design. In our review of the Samsung Galaxy Buds 3 Pro, we found the newer look came with some upgrades, including with comfort and stability in spite of changing things up.
The Buds 3 Pro are still small and nimble, packing in active noise cancelation (ANC) and crisp sound all at once. The ANC continues to remain steady, muffling a wider range of frequencies. Call quality also remains excellent, with some improved clarity to go with it. You can also take advantage of 24-bit hi-res audio support, especially through Samsung's own SSC codec on select Galaxy devices when you want another level in quality. With 360 Audio, you also get spatial audio, including head tracking, to give your ears a surround sound effect.
Battery life gets a little better at up to six hours per charge with ANC on — seven hours if you keep it off. The case gets you three extra charges, which you can charge via USB-C or wireless charging pads. A quick five-minute charge through USB can get you up to an hour of playback.
Best for Pixel users
Google Pixel Buds Pro 2
(Image credit: Tshaka Armstrong)
Specifications
Water-resistance: IP54
Bud battery life: 12 hours
Case battery life: 48 hours
Case size: Small
Speaker size: 11mm drivers
Other features: Adaptive Sound algorithms, translation
ANC?: Yes
Reasons to buy
Good, clear sound with EQ
Integration with Android and Google Assistant
Excellent ANC performance
Great fit and comfort
Reliable media controls
Gemini AI integration
Reasons to avoid
Smaller size could pop these out of your ears
Could use more bass
More ear tip sizes would be nice
When we tested and reviewed the previous Pixel Buds Pro, we found Google finally took a bigger step forward. The sequel finds ways to maintain the momentum while also shaving off 27% off the earbuds themselves. Those with smaller ears might find the Pixel Buds Pro 2 a snugger fit given the slimmer profile. Not that they're exclusive to smaller ears since they should be more comfortable for a variety of ear types.
As with previous generations, the Pixel Buds Pro 2 are tailor-made for Android. Open the case the first time, and with one tap, your Pixel Buds will pair with most modern Android phones. Unless you're using a Pixel device, where the settings are within the phone's system settings, you can download the companion app during setup on other Android handsets to access some of the extras available. Google says it improved the ANC to block out more noise, though the bigger adjustments may be to clearer phone calls and Gemini AI integration.
Like Google Assistant, you can use the AI to help with various tasks hands-free. That also includes translation features on the fly with Google Translate when you need to bridge a language barrier. The touch controls are reliable despite the smaller point of contact to access them. Battery life also gets a boost, lasting longer per charge, and with three extra charges in the case. All in all, the Google Pixel Buds Pro 2 are a stellar pair of smart earbuds for Android users.
Best integration
Powerbeats Pro 2, showing both earbuds in the case
(Image credit: @tshakaarmstrong)
Best integration
Specifications
Bud battery life: 10 hours
Case battery life: 45 hours
Case size: Large
Speaker size: 9.5mm drivers
Other features: Adaptive noise cancellation, Ambient Sound, heart rate monitor
ANC?: Yes
Reasons to buy
Improved sound quality
Finally, ANC and ambient sound
Built-in heart rate monitor
Very comfortable fit
Good battery life
Nice color options
Reasons to avoid
IPX4 rating could be higher
Charging case is still big
It took six years for Beats to come up with this sequel, but the Powerbeats Pro 2 prove their worth in our review. A built-in heart rate monitor is a key differentiator in an otherwise saturated market. Apple users will get more out of these buds but Beats hasn't left the Android bunch behind, either.
To start, sound quality is not only better than before, adding ANC and ambient sound makes these feel light years ahead of their predecessors. Then there's spatial audio for content when you feel like it. There's nothing groundbreaking in how they perform, though a thinner profile and extra ear tips make the Powerbeats Pro 2 fit more comfortably for longer periods. The heart rate monitor works with plenty of devices and apps while you exercise, albeit not with blanket integration on all of them.
That matters at the gym or out on a run, where the ear hooks are crucial for stability. Physical buttons also help with controlling what you want.
Battery life holds up well at roughly eight hours with ANC on, depending on volume levels. The case gives you can extra three charges. It may be 33% smaller but it's not "small", though it's nice to finally have wireless charging.
Best for hi-res
Technics EAH-AZ80 open case view from top.
Best for hi-res
Specifications
Bud battery life: 7.5 hours
Case battery life: 25 hours
Case size: Medium
Speaker size: 10mm
Other features: Ambient Sound
ANC?: Yes
Reasons to buy
Excellent call quality
LDAC support
Good app support
Decent battery life
Reasons to avoid
ANC could be better for the price
LDAC playback affects multipoint connections
Technics may not be the household name others on this list usually are, but in our review of the EAH-AZ80, we found these earbuds to be an excellent pair for their audio quality alone. Audiophiles will fall in love with these high-grade earbuds for sure.
As far as hi-res audio goes, the EAH-AZ80 support LDAC, so when you listen to content from sources offering higher resolution, you should hear the difference when putting these buds in your ears. Plus, the solid app support also gives you a 5-band EQ with six presets and the option to create your own. The earbuds also offer multipoint connections with three devices at the same time, though the LDAC codec can interfere with simultaneous connections. The app offers a variety of custom choices, including whether you want Alexa as your voice assistant or how you want the onboard controls to work.
You won't get ANC on the same level of other earbuds at the same price, so you have to accept that trade-off to get the sonic balance available here. You can expect pretty good battery life at up to seven hours per charge with ANC on or nine hours if you leave it off, give or take how loud you get.
Best value
OnePlus Buds 3 earbuds loose in front of case.
Best value
Specifications
Water-resistance: IP55
Case battery life: 44 hours
Case size: Small
Audio codecs: SBC, AAC, LHDC
Speaker size: 10mm
Other features: Ambient Sound, spatial audio, equalizer, Game mode
ANC?: Yes
Reasons to buy
Good ANC performance
Very good audio quality
Personalized features and functions
Comfortable fit
Solid app support
Excellent battery life
Reasons to avoid
IP rating isn't robust enough
Lacks wireless charging
Stem controls can be finicky
In our review of the OnePlus Buds 3, the earbuds proved their worth in more ways than one, presenting serious value for what they cost. A high level of personalized features drive that, including a hearing test to tailor sound to your ears, along with an equalizer and bass slider to adjust the sound to your own preferences. Use a device that supports the LHDC Bluetooth codec and you can listen to hi-res audio tunes as well. Thankfully, the Buds 3 fit comfortably, which also helps the solid ANC block out a lot of the background. If you're into gaming, Game mode helps knock down latency when playing games. The one weak link in the mix may be spatial audio, though you can always try and see if you like it.
Multipoint support is great to have in any pair of affordable earbuds, and you can connect the Buds 3 to two devices simultaneously. Just too bad there are no wear sensors to automatically pause playback once you remove either earbud. The stem controls are usually responsive, but also finicky at times, making them a little inconsistent that way.
Battery life holds up pretty well at up to seven hours with ANC turned on if you're not also listening to hi-res audio. These earbuds play louder than most at their default volume, so you won't have to crank it up and lose battery in the meantime. You get an extra three charges from the case. In a pinch, a quick 10-minute charge gives you seven hours of playback. The one thing you lose out on is wireless charging.
FAQ
What are the best wireless earbuds?
Like any pair of headphones, which earbuds or wireless headphones are fitting for you is subjective in a few key ways. They have to fit right, feel comfortable over more extended periods, and produce a pleasing sound to your ears. If audio fidelity is paramount for you, there are good options for that, just as there are options for active users or options that present great value without breaking the bank.
The best wireless earbuds strike the right notes where it counts. We're talking about excellent sound quality, excellent comfort, solid microphones, and accessibility — even better when they come at a reasonable price. It's also not just about sound; it can also be about what you don't hear, as active noise cancelation (ANC) becomes such an integral part of what makes good earbuds stand out. That's why it should come as no surprise that such a feature is so common among the best in the business.
For many, the Jabra Elite 10 Gen 2 will be the best option. They strike the right balance in the areas that really matter, like size, sound, durability, and supporting features. They're small enough to fit comfortably in most ears and are rugged enough to withstand water and sweat should you need extra protection. Sound quality is superb, call quality is solid, and the Sound+ app has features worth trying.
Equipped with good ANC, plus unique features to cater to call quality, there's a lot to work with. They provide excellent passive isolation with the proper seal to listen to everything without worrying about the background. You also have physical control buttons that avoid false positives when you press them.
Jabra scored a real winner with these among the best wireless earbuds. They may not come in first place in every category, but it's hard to argue how consistently great they are to use.
How do true wireless earbuds differ from regular wireless earbuds?
In simple terms, true wireless earbuds function without cables and cords. Regular wireless earbuds are "wireless" because they don't connect to the device playing the audio but do have a cable connecting the two earbuds. In that case, the Bluetooth connection from a smartphone connects to one earbud, which then relays that connection to the other earbud through the cable.
True wireless earbuds perform the same function, albeit wirelessly. So, in effect, you have something like a daisy chain, where the phone pairs with one earbud (usually the right one) and then relays that connection to the left. Unfortunately, this method hasn't always been reliable, with audio hiccups and cuts happening. Bluetooth 5.0 has helped improve that, whereas some true wireless earbuds will connect both sides to the phone.
What are the advantages of true wireless earbuds?
The most immediate advantage is that you're not dealing with any wires. There is no chance of cables tangling or accidentally breaking. You have two separate earbuds in a case that charges them on its own. The case has a battery you can charge, meaning that you don't always have to plug it in to charge the earbuds themselves.
Some cases support wireless charging to add more convenience. Most also have USB-C ports for wired charging, some of which also include fast charging.
Despite their smaller size, true wireless earbuds are often equipped with the same wireless earbuds' features. For example, they can include onboard controls for playback or even active noise cancelation (ANC) and voice assistants. In addition, there are models with higher water and sweat resistance and those more focused on increased audio fidelity.
What are the disadvantages of true wireless earbuds?
With no cables connecting the two earbuds, there is always the risk of losing one of them. Moreover, the lack of a cable connecting the two earbuds emphasizes the connection between the two buds themselves. While this has improved, there is a chance that one side's audio may drop out — brief as it may be.
Not having cables makes true wireless earbuds easier to use on a run or during a workout. Comfort and fit are always considerations under those circumstances, but you should also be careful to use them with the right protection in place. That means at least an IPX4 rating or better if you want enough durability for workouts.
The constant charging cycles also take their toll on the lithium batteries' true wireless earbuds and their case use. Not every manufacturer approximates a shelf life, but you may find your earbuds don't last as long after two years with regular usage. Wireless earbuds aren't impervious to these issues, but since they're not cradled in a charging case, the batteries don't go through as many cycles.
Does it matter what Bluetooth version my earbuds have?
Yes, but not always for the reasons you might think. For example, Bluetooth 5.0 doesn't impact audio quality, so having that onboard doesn't mean they will sound better than a pair using version 4.2. On the other hand, updated Bluetooth protocols will impact some things, like how version 5.0 improves range and battery efficiency, for instance.
That additional range could make it easier to walk around at home while wearing your earbuds and listening to music when the phone isn't near you. Usually, major updates to the Bluetooth protocol add higher data transfer speeds, but the benefits aren't always shown with audio quality. Other times, they might.
Still, generally speaking, most of the best wireless earbuds these days have more advanced Bluetooth connectivity.
What are the best codecs for wireless earbuds?
For Android devices, Qualcomm's aptX, aptX LL, aptX Adaptive, aptX HD, and aptX Lossless codecs are generally better than SBC (subband codec), which is the standard codec all Bluetooth audio devices support. The main reason is that aptX has more bandwidth than SBC, which can positively affect audio quality. In addition, AptX Adaptive also automatically adjusts the bit rate in real time to maintain smooth playback and reduce connection drops.
AAC (Advanced Audio Codec) is also standard and is YouTube's preferred codec. While iPhone users benefit from it, it hasn't been as efficient on Android phones. Samsung has its proprietary codec, which it calls Scalable, first introduced in the Galaxy Buds. Its purpose is to be adaptive, so the bit rate and connection don't impact what you listen to. It's exclusive to Samsung's earbuds, so it's not adopted by other brands the way Sony's LDAC is. It also has a variable bit rate, though it's not widely adopted yet.
What are the best wireless earbuds for Android?
By and large, any pair of wireless earbuds will work with Android phones and tablets. Sometimes, you may lose certain features or functionality based on what a brand sets aside for its own ecosystem. That's why Apple's AirPods will pair faster and more seamlessly with iOS devices than they would with Android. It's also why Samsung earbuds may have certain exclusive features that only work with its own products.
Apple doesn't support Qualcomm's aptX codec, whereas Android devices generally do. The flexibility of that codec helps some earbuds do more with Android than they might on iOS. One example of that would be how aptX Adaptive includes the low latency mode, which is beneficial for syncing audio with video while playing games or watching a show or movie.
Even if a pair of wireless earbuds don't support aptX, it doesn't negate their abilities or performance. It matters how the earbuds were tuned to begin with, and it's always a bonus when they have an app they can connect with to let you adjust sound and controls.
How to choose
Finding the right wireless earbuds isn't always about branding or a flashy appearance, it has more to do with how comfortable they fit, how they sound, and how much control you have over what they can do.
For starters, as an Android user, you don't really have to worry much about compatibility. With rare exceptions — like certain AirPods features designed for iOS users — earbuds will work with any Android phone or tablet. There may be particular instances where branding sets some exclusivity, as in how Samsung earbuds integrate with Samsung devices in ways they don't with those from other brands. That kind of integration might be appealing to you if you want it.
How well they'll fit your ears is another thing, though it's usually best to choose a pair of earbuds that come with different ear tip sizes. Some brands offer ear tip tests in their dedicated apps to determine the best fit. You'd be surprised at how one size might be different in one ear compared to the other.
A comfy fit with a tighter seal all but ensures better audio performance, whatever it may be from the pair you're wearing. The passive isolation also helps active noise cancelation do a better job blocking out the background and letting the audio or phone calls sound clearer.
If you hate having to charge your earbuds too often, pay attention to battery life ratings and bear in mind those figures are always based on what the default volume is out of the box. Raise it and the number goes down. Noise cancelation also plays a key role in battery life levels, though it's become standard for manufacturers to clarify expected battery performance based on whether you have it on or not.
AirPods may have notoriety and visibility but they are far from the best in class, which is what makes this list a good place to start. These earbuds are better suited to all users and offer more granular control over the fit and sound you're looking for when listening to your favorite tunes.
How we test
Why You Can Trust Android Central
☑️ One of the oldest and most trusted Android sites on the web
☑️ Over 15 years of product testing
☑️ Thousands of products reviewed and tested since 2007
☑️ Over 30 wireless earbuds tested every year by our audio team
Testing wireless earbuds is a process based on a number of factors. You will see many of those considerations come up in content covering wireless earbuds at Android Central. While we don't run benchmarks or produce graphs to dive into the exact frequencies, we ascertain performance from the experiential side to better explain what you can expect while using them.
After all, earbuds are arguably even more personal than headphones are because how well they fit plays a big role in the overall experience. That requires trying different ear tips or attachments (if they have them) and wearing them for longer periods to gauge what works well. We do our best to account for variances in all aspects, and a lot of that starts with how comfortable they are to wear.
A proper fit helps us understand what audio playback sounds like. And if they don't fit right, we'll always make that clear to you. Just like we go into detail over how they sound — and if available — how you can adjust and tune them more to your liking through companion apps.
That's why it's equally important to thoroughly test all features, like comfort, sound quality, active noise cancelation (ANC), transparency, and phone integration (i.e. calls, voice assistants). How do these features do under different conditions and scenarios? Does the ANC work well in noisier places? Can you count on good sound listening to music and during phone calls? Do manufacturers' battery life claims hold up? Are they rugged enough for workouts?
We try to use wireless earbuds like you would, while also trying to find the nuances, whatever they may be. If they support features like hi-res or spatial audio, we go into that as well. If there's anything special about them, we make sure you know about it.
Ted Kritsonis
Contributor, Audio Reviewer
Ted Kritsonis loves taking photos when the opportunity arises, be it on a camera or smartphone. Beyond sports and world history, you can find him tinkering with gadgets or enjoying a cigar. Often times, that will be with a pair of headphones or earbuds playing tunes. When he's not testing something, he's working on the next episode of his podcast, Tednologic.
With contributions from
