Best controllers for Samsung Galaxy S22 Ultra 2025
The Samsung Galaxy S22 Ultra is a big phone, but there are some great controllers that fit it.
Mobile gaming continues to grow around the world, but even the best Android controllers aren't one size fits all. With new phones comes new requirements, and that's certainly the case with the Samsung Galaxy S22 Ultra. With dimensions of 77.9 x 163.3 x 8.9mm, it can be difficult finding a mobile controller that supports it. Sometimes even being just a millimeter off means a controller's useless.
Luckily, there are several excellent choices on the market that fit the bill — and the Galaxy S22 Ultra — perfectly.
Best of the best
Nacon makes the excellent MG-X Pro controller for Android, designed with grips to mimic the Xbox controller. Rubberized clamps secure phones well so that they don't slip out, making it a great fit for the Galaxy S22 Ultra.
A classic build
Razer makes some of the best gaming accessories in the business, and it went all out with the Razer Raiju Mobile. With hair trigger mode, extra remappable buttons, and a mobile app, it's one of the best mobile controllers you can get.
Nintendo Switch 2.0
The Gamesir X2 Bluetooth controller turns your phone into a Nintendo Switch of sorts. With Bluetooth 5.0 connectivity and a max length of 173mm, it's perfect for the Samsung Galaxy S22 Ultra. It even fits most phones with cases.
Remappable buttons
If you want to use a traditional controller but don't want to find a clip that fits it, there's the PowerA Moga XP5-X Plus. It's lightweight, has extra mappable buttons, and a phone clip built in that can fit the wide body of the Galaxy S22.
Accessorize with a clip
If you already have the 8BitDo Pro 2 controller for Android, then you'll want to upgrade it with this phone clip specifically designed for it. Now you get the best of both worlds: a proper controller and an easy way to prop up your phone.
Tabletop stand for tablets
PowerA's XP7-X Plus stretches up to 7.13-inches, more than enough for the Galaxy S22 Ultra. Though its triggers can feel soft compared to others, everything else about it is wonderful. It even comes with a separate tabletop stand that can support tablets.
Choosing the right controller
Most of the best Android controllers support Bluetooth compatibility because that means they can usually fit more phones. Something like the Razer Kishi, for example, which uses a USB-C connection, doesn't fit the Samsung Galaxy S22 Ultra.
When it comes to choosing the right controller for you, provided you know that it supports your phone, it's all about personal preference. A controller like the Gamesir X2 Bluetooth mimics the design of a Nintendo Switch, and while some people may prefer that, others will want a more traditional design. That's where a controller like the PowerA Moga XP5-X Plus comes in.
Keep in mind that the Galaxy S22 Ultra is still relatively new, so companies may be in the process of creating new controllers that are compatible with it. And if you already have a DualSense or Xbox controller and don't want to spend a ton of money, it's perfectly fine to just grab a separate controller clip that attaches to it. You don't always need to buy a $50 or even $100 mobile controller to get the best experience.
With games like The Division Resurgence, Valorant Mobile, and more popular franchises on the horizon, now's definitely the time to invest in a mobile controller or phone clip. Just remember that not all games may feature controller support.
Be an expert in 5 minutes
Jennifer Locke has been playing video games nearly her entire life. You can find her posting pictures of her dog and obsessing over PlayStation and Xbox, Star Wars, and other geeky things.
