Best Car Mounts for Samsung Galaxy Note 9
When it comes time to get in the car, you'll want to make sure your Galaxy Note 9 is as safe as can be. You could just throw it in the cupholder and hope for the best, or you could pick up a Note 9 car mount for it. Not only does a car mount keep your phone safe while driving (along with a protective case, of course), but it also allows for safer interactions with your phone, whether you're using turn-by-turn navigation, answering a phone call, or anything else. If you've been thinking about picking up a car mount for your Note 9, these are our top picks!
The iOttie Easy One Touch 4 is the go-to car mount for most buyers. It securely attaches to your dashboard or windshield with a strong suction cup, allows you to use your phone in portrait or landscape mode, and has an arm that can be repositioned in several different ways.
If you prefer something cheaper and smaller, Maxboost's magnetic car mount is another great pick. The mount attaches securely to any of your car's air vents, and after attaching a magnetic strip to the back of your phone, it'll latch onto the mount with a powerful force.
Like the idea of a mount that attaches to your air vent but has a more traditional mount design? Enter the Beam Electronics Air Vent Mount. Equipped with 360-degree rotation, a slot for using your charging cable, a quick-release button, and a 1-year warranty, this mount offers a lot more than its $12 asking price might lead you to believe.
If you want to take full advantage of the Note 9's wireless charging capabilities, the ZeeHoo Wireless Car Charger is certainly worth checking out. Not only does it safely hold your Note 9 while in the car, but it also plugs into your car's power outlet to wirelessly charge the phone at the same time!
Vansky's 3-in-1 mount pulls triple duty as a dashboard, windshield, and air vent mount. The installation process is quick and easy, you can rotate the phone holder to use your Note 9 in portrait or landscape, and the suction cup offers an incredibly strong grip. For just $10, you're getting a lot for your money.
Passing military testing for sturdy design, this ultra-rugged car mount can hold the phone on the car dash, windshield, or vent. It can also withstand extreme temperatures, from as cold as -4 degrees Fahrenheit up to as steamy as 194 degrees.
A car mount is your Note 9's best friend
A good car mount should be an accessory everyone has, and that goes for Note 9 owners, too. Among all of the picks on this list, the Note 9 car mount we recommend the most is the iOttie Easy One Touch 4. Time and time again, the Easy One Touch 4 has proven to be one of the safest, easiest to use, and most functional car mounts on the market. Yes, it's a little more expensive than some other options out there, but the attention to detail is unlike anything else.
Speaking of more affordable car mounts, the budget model we'd suggest picking up is the Maxboost Magnetic Car Mount. For the small price you're paying, it's amazing how good the car mount is. It has a super-sticky suction pad and strong magnetic attachment to the phone to keep it securely in place while you drive.
Last but not least, you should also keep the ZeeHoo Wireless Car Charger at the top of your shopping list. It holds your Note 9 just like the iOttie and Maxboost mounts, but it has the advantage of offering built-in Qi wireless charging so you can refuel your Note 9 every time you hop in the car. While not a necessary feature, it is a nice one to have if you can afford it.
Be an expert in 5 minutes
Joe Maring was a Senior Editor for Android Central between 2017 and 2021. You can reach him on Twitter at @JoeMaring1.
