Best Car Mounts for Pixel 4 in 2022
Unless you're using the Android Auto built into your car's radio, you need a car mount for your Pixel 4. You absolutely do not want to be touching your Pixel 4 while you drive, and you absolutely, positively do not want to be distracted should your old, inferior car mount comes crashing down when you're doing 70 on the freeway and crack your Pixel 4's shiny new screen. Get yourself a shiny new mount for your shiny new phone, especially now that we finally have a qi car mount that can charge the Pixel 4 at top speed!
Finally a fast charging option
The Google Pixel 4 requires special efforts to get 10W charging on a third-party charger, and the iOttie Easy One Touch Wireless 2 is the first one to feature it so far. Honestly, if there's only going to be one Qi mount to use it with, I'm happy it's iOttie, because that means it's going to last a long time and that it shouldn't fall off at the first big pothole like some heavy Qi mounts tend to. I highly recommend getting the Air Vent model rather than the dash mount because Qi charging generates heat, and by putting the mount on an air vent, you can use the car's AC to help keep things from overheating.
If you don't care about Qi charging, head for my favorite mount style: magnetic mounts, the Meidi Magnetic Air Vent Car Mount is easy to pocket for business trips, can be easily repositioned if you need to avoid the glare of the setting sun during your long commute home, and has some fun color options like cobalt blue and ruby red. Just stick the metal plate for the mount between your Pixel 4 case and your phone so that it's easily removable if you want to use Qi charging later on.
Ara Wagoner
Ara Wagoner was a staff writer at Android Central. She themes phones and pokes YouTube Music with a stick. When she's not writing about cases, Chromebooks, or customization, she's wandering around Walt Disney World. If you see her without headphones, RUN. You can follow her on Twitter at @arawagco.
Read more
Zendure SuperMini (10,000mAh) USB-C power bank and Zendure Passport III 65W Universal Travel Adapter
Best portable chargers for Google Pixel in 2025
Photo of Android Auto home screen with new wallpaper.
Best USB-C cables for Android Auto 2025
The Pixel 9 in a clear Casetify case with a MagSafe ring
Best Google Pixel 9 and Pixel 9 Pro cases 2025
All four Google Pixel 9a phones in each color (Iris, Peony, Porcelain, and Obsidian) placed artistically against or in front of a wooden display.
Best Google Pixel 9a cases 2025
Chargers with Pixel phone
Best USB-C charger: Fastest phone chargers for Android and iPhone in 2025
The Obsidian Google Pixel 9a held in hand above a houseplant.
Does the Google Pixel 9a support Qi2 wireless charging?
Latest in Google Pixel
Holding an Obsidian Google Pixel 9 Pro
That's not a typo — this Google Pixel 9 Pro deal from Amazon makes Black Friday look like a joke
Pixel Studio app on Google Pixel 9 Pro
Google Pixel teases 'Imagination Studio' pop-up event with a K-Pop girl group
The Pixel 9a and Pixel 9
Google should've split the difference between the Pixel 9 and 9a
The Obsidian Google Pixel 9a held in hand, backlit by a monitor with the words "Google Pixel" flashing behind it.
The Pixel 9a is everything the iPhone 16e wished it was
Pixel 9 Pro XL back view against colorful background
Pixel 10 might see improved startup following a loading process change
The Iris, Peony, Obsidian, and Porcelain Google Pixel 9a in a jumbled pile on a brown desk surface.
Low RAM on the Pixel 9a pushed Google toward a 'limited' version of Gemini
Latest in Buying-guide
Photos of the Nothing Phone 3a series.
Nothing Phone 3a vs. Moto G Power 2025: It all depends on where you live
Apple iPhone 16e review against colorful background
iPhone 16e vs. OnePlus 13R: Quantity versus quality
The Iris Google Pixel 9a (left), Bay Google Pixel 8a (center), and Obsidian Google Pixel 7a (right) on a desk, the photo showcasing their different designs.
Should you upgrade to the Pixel 9a?
Google Pixel 9a vs. OnePlus 13R: Budget battle
The Iris Google Pixel 9a held in hand, the photo taken downards to emphasize its color and size.
Google Pixel 9a vs. Nothing Phone 3a Pro: The sensible and enthusiast picks
