Best Bluetooth keyboards for Amazon Fire HD 10 & 10 Plus 2023
Turn your Fire HD 10 into a productivity powerhouse.
Amazon makes some of the best tablets for watching your favorite shows and playing games, but they can also help you stay productive, too — especially with the Fire HD 10 and 10 Plus. Both have a productivity bundle with a magnetic Bluetooth keyboard and Microsoft 365 subscription; but just because you bought the Fire HD 10 by itself doesn't mean you missed your chance.
You can still buy one of the best Bluetooth keyboards for the Amazon Fire HD 10 and enjoy both worlds — work and play. Some Bluetooth keyboards specifically connect to the Fire tablet, while others will work with any tablet, and can sit in front of your Fire HD 10 if you have a case with a kickstand. Out of all the Bluetooth keyboards out there, we recommend these picks.
Here are some great Bluetooth keyboards for your Fire HD 10 & 10 Plus
Top Pick
The Logitech K380 is the perfect keyboard for anyone who wants a simple keyboard that wants a reliable and comfortable typing experience. This compact keyboard pairs quickly with up to three different devices and allows you to easily switch between those devices with a flip of a switch. Plus, you can get up to two years of use before needing fresh batteries.
Designed specifically for the Fire HD 10
This slim PU leather cover comes in several different color options, including Galaxy and a fake composition book cover. More importantly, it has a magnetically attachable Bluetooth keyboard. Compared to many of the other Bluetooth options, this will stay attached to your tablet in one portable package, making it easier to take both to work or class.
It all adds up
This stainless steel Bluetooth keyboard from iClever is about more than just its looks. It maintains a strong connection to your tablet via Bluetooth 5.1 and lasts up to 90 hours of continuous use between charges. You also get a full-sized number pad built into the keyboard giving your even more functionality while on the go.
Safe typing
This Fintie Bluetooth keyboard case is made to fit your Fire HD 10 tablet perfectly. It will help protect your tablet while you're working on the go, and the detachable keyboard will help keep you on task. Its rechargeable battery can give you up to 400 hours of use and a year of standby. When using this keyboard case, you might forget you're working on a tablet and not a laptop.
Night type
When day turns to night, and you still have work to do, you'll appreciate this backlit keyboard from Arteck. This keyboard's rechargeable battery powers not only your productivity sessions but also its LED backlight. You'll have seven different colors to choose from and two different brightness settings — so no more straining to see your keys.
Touch and go
Even though when working on an Amazon Fire HD 10 tablet, you can use the touchscreen to move your cursor, sometimes a mouse is easier — but you don't want to carry another device. That's where this Bluetooth keyboard from Fintie comes in with its built-in touchpad. You get an excellent typing experience and a touchpad, and it all fits into an ultra-thin 4mm device.
Ready to work, anywhere
These days you can be productive almost anywhere with a great Android tablet. With the Amazon Fire HD 10 tablets, you get a powerful device with a beautiful 10.1-inch screen that's perfect for watching movies and getting your work done. However, when it's time to buckle down and do some typing, an on-screen keyboard isn't always the best option. This is when it's helpful to have a great Bluetooth keyboard handy.
If you only have long typing sessions every now and then, you will probably want to pair up the Logitech K380 with one of the best Amazon Fire HD 10 cases. This way, you can prop up your tablet while getting work done on this reliable and comfortable Bluetooth keyboard. But, if you want to be ready when the moment strikes, and you need to type as efficiently as possible, go for the Amazon Bluetooth Keyboard case. Not only is it an excellent keyboard, but you'll have everything you need in one device.
Be an expert in 5 minutes
- Michael L HicksSenior Editor, Wearables & AR/VR
