Best Alexa-Compatible Smart Home Devices for Amazon Echo in 2022
Smart home tech is becoming a more accessible and popular way of upgrading your current household setup. The best thing about the Amazon Echo family of products and Amazon Alexa is the seemingly endless integration with many popular and emerging smart home devices. Here is a smorgasbord of some of the best Alexa-compatible smart home tools that work with your Amazon Echo device.
The Ring doorbell works with Echo to provide a screen and show you who is near your doorbell. It has a horizontal view of 180 degrees and a vertical view of 110 degrees.
This smart lock connects to your existing deadbolt setup. Once installed, just ask Alexa to lock or unlock the door. Plus, set your door to lock and unlock when it detects you coming or going.
The Nest Learning Thermostat connects to up to 20 thermostats in your home and lets you control and program them all together, or individually from the app or with Amazon Echo.
The iRobot Roomba works with Alexa to make cleaning up messes around your home a breeze. It can run 90 minutes before needing to dock and recharge and works on hard floors and carpet.
Ask Alexa to change your Philips Hue lights to any colour you wish, dim your lights, or set a lighting scene via the Philips Hue Alexa skill.
Installing the Sonos skill for Alexa will let you play and control the music on your Sonos Play:1 on command. You can install a second Play:1 for stereo quality sound.
This 4K smart television is recommended for applications from gaming, to movie watching, and connecting devices through USB and HDMI. You can also control the television from Echo devices.
This universal remote control connects to televisions and other smart devices, like lights, thermostats and locks. Use voice controls when connected to Amazon Echo.
Integrating with Alexa lets Deco owners control different aspects of their home network, including opening and closing guest networks and managing QoS modes.
This router is built with gaming, streaming, and mobile devices in mind. With Dynamic Quality of Service, this router detects what device you're using and prioritizes bandwidth for it.
These first-party smart plugs can pair instantly with your Echo devices and turn any dumb appliance into a smart one with Alexa.
What's your setup?
Making your home a little smarter can be a lot of fun. Using the Nest Learning Thermostat, Philips Hue Ambiance lights and the iRobot Rumba all make daily living a bit easier while also helping free up valuable time for more important tasks.
If you don't want to upgrade to Alexa-enabled devices, you can create smart ones by simply plugging them into an Amazon Smart Plug. Just plug your device in and control it with the sound of your voice. Turn a non-smart lamp into a smart one, for example.
Of course, this investment should be kept safe. We recommend starting with the Ring Doorbell and the August smart locks. Both of these devices can be voice-controlled using your Amazon Echo and include apps, also voice-activated, so they can be turned on or off when you're not at home.
Be an expert in 5 minutes
Jeramy was the Editor-in-Chief of Android Central. He is proud to help *Keep Austin Weird* and loves hiking in the hill country of central Texas with a breakfast taco in each hand.
