Best 10 Samsung Galaxy S6 edge+ cases
We're rounding up the top ten cases for the Samsung Galaxy S6 edge+. These span the gamut of slim cases, heavy-duty rugged cases, wallet cases, and anything else that will keep your edge+ covered.
As always, we're eager to hear what you're using, too. Leave a link in the comments to your favorite Galaxy S6 edge+ case.
Urban Armor Gear
The Urban Armor Gear case for the Samsung Galaxy S6 edge+ offers tough protection. Extra rubber cushioning around the corners take the brunt of of impact from drops, while a hard plastic backing keeps your phone covered from scratches. Users keep full access to important inputs and buttons, like volume, 3.5 mm audio, USB, and power. You can pick the UAG case up in a grey, silver, and red finish.
Samsung Clear View Cover
The Samsung Clear View Cover offers simple protection for your screen while still letting you take calls without having to open it. The software on your S6 edge+ software recognizes when the cover is closed and continues to display the clock, alarms, and incoming call alerts. Touch input is recognized so you can expand each for a preview. Of course, you also get some coverage around the back, too. Gold, silver, and blue models are available.
Spigen Slim Armor
The Spigen Slim Armor case is a two-layer case with a built-in kickstand. An air cushion around the corners provide a little extra room for the case to collapse slightly when dropped. A raised lip along the top and bottom provide additional clearance for the front of the screen, while leaving the edges open for your usual gestures and functions. The Spigen Slim Armor case is available in gold, grey, teal, and purple.
Ringke Fusion Crystal
If you want to keep showing off the style of your S6 edge+, the Ringke Fusion Crystal is a well-loved clear case. Dedicated plugs protect USB and headphone ports, while you still have passthrough access to the hardware keys. There's also a lanyard loop if you need one. A special coating helps keep scratch marks to a minimum, and minimizes static which usually traps dust between your phone and the case. You can also get a variant model with a dark grey border around the rim.
Speck CandyShell Grip
The Speck CandyShell Grip is a stylish two-tone case with rubber interior and ridged back. Those ridges add a ton of grip, perfect for those that are nervous about occasional slips. Extra padding at the corners is always welcome, helping protect against common drops. There's a generous range of color options available, including black and white, blue and purple, green, and plenty more.
Heavy Duty Supcase
Supcase has an extra-tough case for your Samsung Galaxy S6 edge+ with an integrated screen protector. A belt clip holster comes included for additional flexibility. Rubber plugs cover USB and headphone inputs to protect against dust. From a sheer style perspective, the Supcase looks like it means business. You can get the Heavy Duty Supcase in black, blue/black, green/grey, and white color schemes.
OtterBox Symmetry
The OtterBox Symmetry series is a well-respected lineup of two-layer cases. Hard plastic and rubber sections work together to protect against both scatches and impact. A raised lip around the screen ensures extra security. OtterBox has been doing phone cases for a long time, and they test the heck out of everyone they make. You can rest assured that they're well-made. There are plenty of color options for the Symmetry case, including black, white, pink, and blue.
Verus Layered Dandy Wallet
The Verus Layered Dandy Wallet case lets you store three credits cards and some cash alongside your Samsung Galaxy S6 edge+. A magnetic clasp keeps the front leather flap secure, and a cutout for the earpiece lets you take calls while it's closed. You'll also get all-around protection, even for the corners, but ultimately you're getting a healthy dose of classic style. Black, brown, and red leather options are available.
Incipio DualPro
The Incipio DualPro case is a simple, effective, hybrid case. A soft-touch layer lets you press the hardware keys through the case, while the hard layer provides solid protection against the elements. It's a subtle combination, but one that works quite well if you want something that's no-frills. You can grab the DualPro in pink, grey, and black.
Seidio Dilex Pro
Seidio's Dilex Pro two-piece case for the Samsung Galaxy S6 edge+ has a built-in kickstand. An integrated hard plastic and soft rubber layer ensure your phone stays protected from all angles. The Dilex Pro includes a felt-lined holster clip for storage while on the move. Black, blue, and red colors are all available.
Your favorite case for the Samsung Galaxy S6 edge+?
Those are our picks for the best protection available for the S6 edge+, but sing out in the comments with a link to your favorite cases. We're always on the hunt for more!
Be an expert in 5 minutes
