Be the life of the party with the LG XBoom 40W speaker system at a low price of $50
Xboom Go
Xboom Go (Image credit: Amazon)
The LG XBoom 40W speaker system and subwoofer combo set is on sale as part of Best Buy's deals of the day. You can get the combo for $49.99 today only. It normally sells for around $80 and regularly hits as high as $130. The same audio system goes for $80 at B&H.
LG 27GL850-B 27-inch Ultragear Nano IPS G-Sync compatible gaming monitor
$386.99 $450.00 Save $63
The specifications include a 1440p pixel resolution, a 144Hz refresh rate, and a 1ms response time. With an IPS panel, you get great viewing angles and color accuracy. Plus the native adaptive sync works with AMD and Nvidia graphics cards.
LG OLED55CXPUA CX Series 55-inch 4K OLED Smart TV 2020 with Alexa
$1,350 + Free Speaker
Deal works with larger TVs, too. The CX series includes an advanced processor for 4K upscaling, LG's webOS smart platform that can access all of your favorite content and streaming platforms, features like G-Sync just for gamers, and more.
LG 27GN800-B 27-inch 1440p IPS Ultragear gaming monitor
$296.99 $400.00 Save $103
A great monitor that includes a 2560 x 1440 pixel resolution, a 144Hz refresh rate, and a 1ms response time. It has an IPS panel for great viewing angles. It's also G-Sync compatible with FreeSync native support.
LG 27GN800-B 27-inch UltraGear 1440p gaming monitor
$346.99 $462.00 Save $115
Add the monitor and an Xbox controller of any color to your cart and you should see $114 taken off when you go to checkout, giving you the controller for free and reducing the price of the monitor to $347, which is what it's going for elsewhere.
LG UltraGear 24GN600-B 24-inch 1080p IPS monitor
$179.99 $220.00 Save $40
This is a model unique to Costco. The monitor has an IPS panel for great color accuracy. It also has a 144Hz refresh rate and 1ms response time. Includes FreeSync, two HDMI ports, one DisplayPort, and wall mounting capability.
The system comes with two 10W speakers and one 20W subwoofer for a 40W output. You can use it as a PA entertainment system, which makes it great for parties, backyard barbecues, and family gatherings. Not only can you fill a room with music, you'll get some thumping bass in the process.
The audio system has an amplifier, digital player, radio, and Bluetooth receiver. That gives you plenty of options for streaming your favorite tunes or tuning into a bumping radio station. Use the radio's FM tuner to find your favorite stations or connect through the Aux or USB inputs to play from your favorite mobile devices.
You'll also get a remote control you can use to control it from a distance.
