buying guides
Latest about buying guides
Best dumb phone 2024
By Namerah Saud Fatmi last updated
The opposite of smart Take some downtime from the internet with the help of a good old dumb phone. These feature phones nail the basics, and they're super easy to use, making them perfect for just about anyone.
Best USB-C cables 2024
A C of cables Here's what you need to know about the best USB-C cables and which ones match your needs. Follow these easy tips to make the best choice.
Best Android phones with a headphone jack 2024
Plug and play The 3.5mm headphone jack has nearly gone extinct, but these excellent Android phones are still holding on to it. Here are some of the best ones you should consider if you need to plug in.
I've tested dozens of wireless earbuds, and these are the pairs you should buy in 2024
By Ted Kritsonis last updated
Enjoy in-ear audio The best wireless earbuds balance great sound with all-day comfort, plus a little bit of bang for the buck. Here are the best options that money can buy.
Best Garmin watch 2024
By Michael L Hicks last updated
Best for fitness training These are the best Garmin watches across the Venu, Forerunner, Instinct, Fenix, and other Garmin lineups, for every type of athlete.
Best microSD cards for Android 2024
By Andrew Myrick, Christine Persaud last updated
Store more Expandable storage is only as good as the memory card you use to facilitate it. These are the best microSD cards you can buy for your Android device.
What color Google Pixel 9 Pro or 9 Pro XL should you buy?
Pixel color wheel Both the Google Pixel 9 Pro and Pixel 9 Pro XL come in the exact same colors. Let's mull over which color you should pick.
Best Android phones for students 2024
Best phones Power through your course load this year with a new phone that stays in line with your student budget. Here are our picks for the best Android phones for anyone going back to school.
Be an expert in 5 minutes
