Get this wireless charging power bank on sale at Amazon for only $27 right now
The Aukey Basix Pro makes powering up your devices easier than most portable power banks can muster. This 10000mAh portable charger doubles as a wireless charger that you can use on-the-go. Plus, with its USB-C port, you'll be able to use its Power Deliver 3.0 and Quick Charge 3.0 output to charge at up to 18W.
Though the Basix Pro portable battery charger normally sells for $40, today you can pick one up on sale for only $26.99 when you clip the coupon on its product page at Amazon and then use promo code WVHYH3BT during checkout. That saves you close to $15 off its regular cost.
The Basix Pro portable charger is a stellar choice to power up pretty much any USB-powered device. It has two charging ports you can use to power two devices simultaneously, including a USB-C port with Power Delivery 3.0 and a USB-A port with Quick Charge 3.0. That means you'll be charging your devices much quicker than standard chargers can.
Along with the two charging ports, this charger also has a wireless charging pad built-in so you don't even need to plug in your device to power up if it's Qi-enabled! The charger has an 18W total output and takes less than four hours to charge fully. Plus, built-in safeguards work to protect your connected devices against excessive current, overheating, and overcharging.
Amazon offers free shipping on orders totaling $25 or more, though you could receive your order even faster with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum. You'll also gain access to the rest of Prime's perks such as the Prime Video streaming service, exclusive members-only discounts, and more.
