Aukey's new Fast Charge wireless charging pad is down to $16
You are now subscribed
Your newsletter sign-up was successful
Aukey has a new wireless charging pad with some new tech! The LC-Q7 wireless charging pad is temporarily down to $15.99 with the code BRRHDHMS at Amazon. Without the code, the charging pad is going for $20, and we imagine it's going to be stuck at that price for a while without codes like this. Think of this as an early adopter discount because it'll probably disappear soon.
Aukey 9-in-2 USB-C hub for MacBook Pro or MacBook Air
$41.99 $60.00 Save $18
Unique design requires two USB-C ports back-to-back, which is why this is particularly suited for a MacBook that has such a configuration. Turn those two ports into nine tools including HDMI, Thunderbolt 3, and a 100W Power Delivery charging port.
Aukey Sports true wireless earbuds with earhooks
$27.49 $50.00 Save $23
Include powerful 12mm drivers for high-fidelity audio. The ear hook design won't let go even when you're at the gym. They have IPX8 water resistance, which is full waterproof support. The battery life lasts up to 35 hours with the included case.
Aukey Bluetooth true wireless earbuds
Up to 30% off
All the prices are discounted and the costs vary between $21 and $49. All you have to decide is which one looks best to you and has the features you need (like the Sports earbuds that stay on even while you run). Choose from black, white, and pink.
Aukey KM-G6 LED Mechanical Gaming Keyboard
$27.99 $44.99 Save $17
This well-reviewed keyboard features 104 anti-ghosting keys, nine preset lighting effects, and even comes with a two-year warranty. Today's deal at Amazon saves you $12 off its regular price while supplies last!
$25.24 $50.00 Save $25
So one thing this charging pad does that's new is it uses three different charging coils on the inside. That means you can place your phone basically anywhere on the pad to get a full charge. It's not like other devices where you have to center your phone, get the dimensions right, break out the ruler and judge the distance from the edge. Sometimes you just want to plop your phone down and go to bed, and with this pad you can do that and wake up to a fully-charged device.
The pad works with pretty much any Qi compatible device. It provides up to 10W for Android phones like the Samsung Galaxy S10 that have Fast Charge, 7.5W for the iPhone 11 lineup, and 5W for other standard wireless charging devices. If you want that extra speed with your Android phone, the pad will need to be using a wall adapter that supports Fast Charging or Quick Charge like this one from Anker.
The pad's design uses a soft silicone surface that also keeps your phone in place while it's charging. Your phone won't slip off, and the pad won't slip either thanks to the padded feet on the bottom. You'll also get built-in safety features that help regulate the temperature, detect foreign objects, and prevent things like overheating. Aukey backs this up with a two-year warranty, too, just like all Aukey products.
