Aukey's highly-rated car phone mount is only $5 right now
Driving with your phone in your hand is both dangerous and stupid. That doesn't change the fact that sometimes you need to use your favorite GPS app. A good phone holder can keep your screen in sight while ensuring your eyes don't wander far from the road, and today you can use coupon code QLSVDAXA during checkout at Amazon to get this well-rated Aukey Car Phone Mount for only $5.49. That saves you nearly 50% off its typical $9.99 price tag, and it also gets you in on one of the best deals we've seen yet for this particular item. Since shipping fees would make the deal less enticing, you should spend at least $25 or use Amazon Prime to avoid them.
Aukey 9-in-2 USB-C hub for MacBook Pro or MacBook Air
$41.99 $60.00 Save $18
Unique design requires two USB-C ports back-to-back, which is why this is particularly suited for a MacBook that has such a configuration. Turn those two ports into nine tools including HDMI, Thunderbolt 3, and a 100W Power Delivery charging port.
Aukey Sports true wireless earbuds with earhooks
$27.49 $50.00 Save $23
Include powerful 12mm drivers for high-fidelity audio. The ear hook design won't let go even when you're at the gym. They have IPX8 water resistance, which is full waterproof support. The battery life lasts up to 35 hours with the included case.
Aukey Bluetooth true wireless earbuds
Up to 30% off
All the prices are discounted and the costs vary between $21 and $49. All you have to decide is which one looks best to you and has the features you need (like the Sports earbuds that stay on even while you run). Choose from black, white, and pink.
Aukey KM-G6 LED Mechanical Gaming Keyboard
$27.99 $44.99 Save $17
This well-reviewed keyboard features 104 anti-ghosting keys, nine preset lighting effects, and even comes with a two-year warranty. Today's deal at Amazon saves you $12 off its regular price while supplies last!
$25.24 $50.00 Save $25
This phone mount adheres securely to your windshield, dashboard, or another surface using the incorporated suction cup mounting mechanism. It features a 360-degree rotatable ball joint that allows you to adjust the viewing angle to best suit your needs. The phone cradle is compatible with smartphones measuring up to 6.5 inches as well. Should you ever need to remove or adjust it, simply rinse the suction cup and it will be ready to go. Just over 200 customer reviews have left the mount with an average of 4.1 out of 5 stars. Aukey also includes a 24-month warranty with your purchase.
A phone holder like this is also a really good option if your car doesn't have traditional vents. Since it adheres to your windshield or dashboard, it can be a nice way to keep your phone out of your hands if your vents don't play nicely with traditional phone mounts. However, if you do have traditional vents, and you want to keep your dashboard free of clutter, a holder like this magnetic phone holder is a more streamlined solution, and it's pretty inexpensive as well.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
