Aukey offers USB-C cable 3-packs for as little as $9, 5-packs for $14
USB-C has been slowly taking over, and recently we've seen more and more electronics include it as the standard charging method. While USB-C has plenty of advantages, this change means that all of your old cables are no longer compatible, and now you'll need a bunch of new ones.
Right now, Aukey is offering some pretty nice discounts on its 3 and 5-packs of USB-C cables, which helps make the transition a bit more affordable.
You can grab a basic 3-pack for as little as $8.67, or opt for the braided ones which are perfect for those who are a bit harsher on their cables for just $11.75. You'll need to use a coupon code during checkout at Amazon to get these prices, so be sure to use the matching coupon code below for the listing you select.
- AUKEY 3-Pack 3.3ft USB 3.0 A to C Cables - $8.67 with code ZWNJXQ3W
- AUKEY 3-Pack 3.3ft USB 3.0 A to C Cables (Braided Nylon) - $11.75 with code CY5ZAFLT
- AUKEY 5-Pack USB 3.0 A to C Cables (3.3ft x 3, 6.6ft x 1, 1ft x 1) - $13.91 with code 5WNZTKWO
- AUKEY 5-Pack USB 3.0 A to C Cables (Braided Nylon, 3.3ft x 3, 6.6ft x 1, 1ft x 1) - $14.95 with code P8633ONW
Be sure to stock up on these cables now, your future self will thank you later. Aukey also has a variety of other USB-C accessories discounted right now to celebrate the announcement of the new Google Pixels. Save 15% on these using coupon code PIXELDAY.
For more great deals be sure to check out our friends at Thrifter now!
Be an expert in 5 minutes
