Plug in all the things with AUKEY USB hubs starting at $10
Amazon is offering a variety of AUKEY USB hubs at a discount today. Prices start at only $10.39, and shipping is free with Amazon Prime. Be sure to use the correct coupon code for the hub you're purchasing. All of these options are well-rated and meet or beat the best deals we've seen for them.
First up, we have the AUKEY USB 3.0 4-Port Hub. Typically, it costs around $12.99, but today you can drop that price to $10.39 with coupon code NYVP9OW6. This well-rated USB hub turns a single USB-A port into four. That'll give you plenty of connectivity options if your computer is lacking. It handles transfer speeds at up to 5Gbps and the form factor is lightweight and portable too.
If you're on the hunt for a USB-C option instead, check out the AUKEY 5-in-1 Hub. It'll drop from $19 to $15 with coupon code 85NX78GN. The hub features three USB-A ports, plus a reader for SD and microSD cards. That's plenty of functionality for the average user. Alternatively, for even more options, use code NYVP9OW6 to drop this AUKEY 7-in-1 USB-C Hub to $35.99. That's nearly $15 off the normal cost, and this model has the same ports as the aforementioned USB-C version, with the addition of two additional ports.
Louryn Strampe
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
