Arlo Essential vs. Wyze Outdoor: Which should you buy?
Arlo Essential
While it costs a bit more, Arlo Essential provides the essential experience for smart home security cameras. While it's not as inexpensive as Wyze Outdoor, it's still less expensive than many other options on the market, and still doesn't skimp on important features like advanced motion detection, color night vision, and automated track and zoom.
Arlo Essential
More bang for your buck
Wyze Outdoor
Wyze regularly undercuts its competitors' prices with every product release, and Wyze Outdoor falls right in line with that anthem. At a barebones price, Wyze Outdoor offers far more than a barebones experience. Quality video, up to six months of battery life, free local and cloud storage, and even great motion detection options make this a well-rounded value option.
Wyze Outdoor
Smart price, brilliant decision
Arlo Essential vs. Wyze Outdoor: A similar concept
Despite the substantial price difference, both the Arlo Essential and the Wyze Outdoor Cam operate on the same principles. Both cameras are outdoor-rated security cameras that can detect motion, have two-way audio for hearing what's going on and speaking to whoever might be on the other end, and both feature a built-in rechargeable battery that lasts several months. Each camera delivers high-quality 1080p video with digital zoom capabilities, the ability to see in the dark up to 25 feet away, and even maximum operating temperatures for some of the hottest and coldest climates people live in.
Unlike some other home security cameras on the market, both the Arlo Essential and Wyze Outdoor Cam allow users to choose between local or cloud storage like Arlo Smart. Both cameras can add in AI-powered people detection with a low-cost monthly subscription, and both cameras will hook up to your favorite smart home service for deeper integration into your smart home. Best of all, both are affordable compared to others on the market, even if the Wyze Outdoor is the most affordable.
Wyze Outdoor: Saving a buck (or a lot)
Cost can, sometimes, be an accurate indicator of quality or the number of features a product will deliver. In the case of Arlo Essential vs Wyze Outdoor Cam, you're absolutely going to get more when you pay more. Wyze has always focused on delivering a great product for considerably less than the competition, and it'll often do this by offering exactly what the customer needs while shaving off some of the seemingly superfluous features.
Header Cell - Column 0 | Wyze Outdoor Cam | Arlo Essential |
Price (MSRP) | $60 for starter kit, $47 per camera | $130 |
Hub required | Yes | No |
Max Resolution | 1080p | 1080p |
Dimensions | 2.3 x 2.3 x 2.8 inches | 3 x 2 x 3.5 inches |
Frames per second (FPS) | 20 | 30 |
Lens FOV | 110 degrees diagonal | 130 degrees diagonal |
Zoom | 8X Digital | 12X Digital |
Auto Track and Zoom | No | Yes |
Night Vision | Black & White; 25ft distance | Color and B&W; 25ft distance |
Integrated Spotlight | No | Yes |
Power Source | Integrated battery | Integrated battery |
Battery Life | about 3–6 months | about 6 months |
Operating Temperature | -4° F to 122° F (-20° C to 50° C) | -4° F to 113° F (-20° C to 45° C) |
2-way Audio | Yes: Single Microphone | Yes: Single Microphone with noise and echo cancelation |
Sound Detection | No | No |
AI Features with Subscription | People detection | People, package, animal, and vehicle detection |
Local Storage | Yes, up to 32GB via microSD card | Yes, up to 2TB via smart hub |
Cloud Storage | 2 weeks of 12-second clips for free, full-length videos with subscription | 30 days of clips with subscription |
Smart Home Connectivity | Amazon Alexa, Google Assistant, IFTTT | Amazon Alexa, Google Assistant, Apple HomeKit, IFTTT |
That much is certainly true with the Wyze Outdoor Cam, which retails for $60 and offers the same basic quality and functions that all other smart home security cameras on the market do. The biggest difference users will see between the two cameras lies in the additional functions that Arlo offers on its cameras.
It's extremely difficult to argue with Wyze's price here. At under $50 per camera, Wyze Outdoor is less than half the sale price of the Arlo Essential — which normally retails for $130 — yet still offers compelling features that would likely fulfill most consumers' needs. Aside from price, the biggest value-added advantage Wyze offers is in its cloud storage options, which will save 12-second clips for up to two weeks without any additional cost.
Be an expert in 5 minutes
Arlo Essential: It's the little luxuries
So Wyze offers an incredible value that's seemingly impossible to compete with, but what about all the additional features that Arlo offers? While it's going to cost you twice as much to outfit your home with Arlo Essential cameras, the little luxuries could just be enough to sway you. From the get-go, Arlo Essential is less complicated since it doesn't require a hub to connect to the internet like the Wyze Outdoor does. That's one less thing to plug in, which is a particular plus since this is a wireless camera system.
If you already have an Arlo hub from other Arlo cameras or devices, Arlo Essential can store all recorded videos locally to one central location. On top of that, Arlo supports up to 2TB of local storage, while Wyze only has 32GB on each camera. Arlo also offers an official solar panel that can be purchased separately and used with each Arlo Essential camera so you don't have to worry about charging.
While both companies require a monthly subscription in order to enable advanced motion detection, Wyze only offers the people detection feature as a way to help cut down on false positives. Arlo, on the other hand, ramps this up with detection for people, packages, animals, and vehicles, so you can tell right from your phone's notifications what your camera saw. You can even zoom in 4x more with Arlo Essential than you can with Wyze Outdoor, which could come in handy when trying to see things far away.
Another truly excellent feature in Arlo's repertoire is the built-in spotlight, which can turn on automatically when motion is detected. There's nothing quite like warding off an intruder with a spotlight pointed right at them. The spotlight also means Arlo Essential has color night vision options but, if you would rather use infrared light, black and white is still available. Lastly, the higher framerate at which Arlo Essential records delivers smoother video than Wyze Outdoor.
Arlo Essential vs. Wyze Outdoor: A narrow win
Arlo Essential delivers a better overall experience with more features, and even though it's more than twice the price of Wyze Outdoor, the overall price is still quite a bit lower than most competing cameras on the market. Arlo's excellent cloud storage and advanced motion detection options give it a distinct advantage when subscribed to an Arlo Smart plan. Ultimately, it's a budget-friendly camera that feels more like a higher-priced experience.
However, if you just want to save some money and add more cameras to your home without breaking the bank, it's very hard to argue with what Wyze Outdoor Camera offers. You'll get all the basics and a bit more with Wyze Outdoor, all while spending less than half the price of what it would take to outfit your home with Arlo Essential cameras. Don't need the extra features? Wyze Outdoor really is a phenomenal choice.
