Anker's Soundcore Liberty 2 True Wireless Earbuds are down to just $59.99 in refurbished condition via Anker's official store at Newegg. These earbuds normally go for $100 brand new and $80 refurbished.
This is one of the lowest prices we've seen for the Soundcore Liberty 2 since their release, though the deal is available today only. To get that low price, all you have to do is enter coupon code 93XPQ62 during checkout. Shipping is free.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker's Soundcore Liberty 2 are some of the best affordable true wireless earbuds available. They feature a diamond-coated driver for flawless accuracy and an elastic, bass-maximizing ridge around the exterior to pump up your music a bit further. Using HearID technology, you can create a custom set of EQ settings for these earbuds; it even maps your hearing sensitivity at various frequencies to give you a personalized listening experience. There's also AptX technology for high-quality audio over Bluetooth.
These earbuds last for up to eight hours on a single charge, and with the included charging case, you can power them up an additional three times while on-the-go. That extends the total listening time up to 32 hours before you'll need to power the case up again. What's great is that the earbuds can be charged up for two hours of listening time within just ten minutes in case you realize they're powerless right when you wanted to put them to use.
Anker includes seven pairs of various sized EarTips as well as three pairs of EarWings to help personalize the fit of these earbuds for your ears. With Anker's proprietary GripFit technology, they sit securely, yet comfortably, in your ears with a simple twist.
Be an expert in 5 minutes
