Anker's PowerWave wireless charging phone mount is down to $37 at Google Express
Charging your phone in your vehicle just got a lot easier. Anker's PowerWave Fast Wireless Charging Phone Mount lets you wirelessly charge your phone while you're driving by just placing it in this sturdy phone mount. While this setup normally retails for $60, you can grab it at Google Express for only $36.79 right now when you enter code SEPTSAVE19 during checkout for 20% off. That's almost $10 less than it's currently going for at Amazon. Note that the code only works on your first Google Express order.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerWave combines a phone mount with a Qi-enabled fast wireless charger for one fancy gadget. It can charge up an iPhone 8 or newer at 7.5W and Android phones from the likes of Samsung and LG can benefit from a 10W fast charge on the move. If you are using an advanced enough Android phone to take advantage of the faster charging, you'll want a Quick Charge 3.0 car charger to get top speeds. Fortunately, you can pick one of those up pretty affordably with the money you save. As well as the charging mount, you also get the necessary USB cable for hooking it up to power and two air vent grips with your purchase.
The device will also work through cases so you don't have to take them on and off and it rotates 360 degrees so you can mount your phone in any orientation. You'll get an 18-month warranty from Anker and existing users give it 4 stars based on over 300 reviews.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
