Anker's PowerPort 6 power strip has AC outlets, USB ports, and a new low price of $22
Isn't it about time you had power strips at home that were actually compatible with all the charging cables you use on a regular basis? You can ditch those bulky USB wall chargers and switch to the Anker PowerPort 6 USB Power Strip instead. It's packed with six AC outlets and three USB ports so you can plug your charging cables in directly, and today you can pick one up for just $21.99 at Amazon when you clip the on-page coupon. That saves you nearly $15 off its full price of $36, and it also marks the best price we've ever seen this model reach.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker's PowerPort 6 has a total 18W output for its USB ports, and with the six surge-protected AC outlets, you'll be able to provide power and charge up to nine devices simultaneously. Anker implemented advanced charging technology to deliver an optimized charge per device so you don't have to worry about over-charging. Plus, safety features such as surge and overload protection work to keep you and your devices safe. It also features a fire-resistant casing and a safety switch, as well as a six-foot power cord.
Anker includes an 18-month warranty with this power strip's purchase. Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
