Anker's PowerCore Fusion 5000mAh portable charger has dropped in price to $40 today only
Fusion
Fusion (Image credit: Amazon)
The Anker PowerCore Fusion 5000mAh USB-C portable charger is down to $39.99 at Best Buy. The sale is one of Best Buy's deals of the day, which makes this a very temporary thing. Grab it while you can. The PowerCore Fusion normally sells for $100 at Best Buy and closer to $60 elsewhere.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Anker PowerCore Fusion 5000 is a two-port charger with one USB-C port and one USB-A connection. You can get an extra full day out of your iPhone with this extra boost of battery. The USB-C port has Power Delivery and 30W power, which means you can also use it to charge a laptop like a MacBook or a tablet or any device that uses USB-C. The USB-A port has 12W power and the two can be used simultaneously to charge multiple devices. With PowerIQ tech, you can plug in your Android phone or Windows ultrabook and the charger will know exactly what it is and deliver the best possible charge.
It manages to do all of this while still being small enough to fit in the palm of your hand. Plus, it has a foldable plug so you can easily stuff the charger into your backpack or purse and keep it close all day. The outside features a scratch-resistant coating, which means it won't get messed up bouncing around in your bag.
