Anker's Nebula Soundbar with built-in Fire TV is down to its best price yet
Late last year, Amazon and Anker announced a joint project for your living room in the form of the Nebula Soundbar — Fire TV Edition. Essentially, it combines the smarts of a Fire TV Stick 4K with the audio-quality of a 2.1 channel soundbar in one device. It retails for $229 and has not deviated from that price until this month. Right now you can score one for just $195 which is the lowest it has gone since its release, though you'll have to act fast to get one at that price.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Watching your favorite movies and TV shows is way better on a high-res screen. While you might have already upgraded your TV set, you can really make your favorite content sing with a soundbar. The Nebula Soundbar features a 2.1 channel design that combines 2 speakers and 2 subwoofers to create 100W of room-filling sound. While it might not compare to a high-end Sonos system, it'll be way better than your TV's built-in speakers and it's a steal at today's price.
As well as providing stellar audio, the Fire TV inside supports 4K resolution and 60 frames per second, as well as Dolby Vision for HDR. Of course, it's also got support for Amazon Alexa built-in via the included remote control. That means you can have Alexa control your soundbar and compatible TV functions like power, volume, navigation, and playback. You can also ask Alexa to find your favorite content.
Combining the Fire TV capabilities with your soundbar means you only have to plug one thing into your TV for both functions, freeing up another port for your console or other smart devices. The Nebula Soundbar also has a slim profile which helps it save space on your TV stand, and it also comes with wall-mounting hardware.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
