Anker's Liberty Neo true wireless earbuds have an updated sound and are down to $40
The Anker Soundcore Liberty Neo true wireless earbuds are down to $39.99 on Amazon when you clip the $10 off on-page coupon. The coupon is augmented by a $5 price drop because these earbuds normally sell for $55, and this is the first time we've seen drop from that price directly. This also a new version of the Liberty Neo. We have seen the older models drop to this price before, but the last deal was a couple months ago.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Liberty Neo earbuds use graphene drivers, which are harder than steel and 35% lighter compared to traditional drivers. They offer extreme precision, exceptional accuracy, and crystal clear audio. You can also increase the low frequencies up to 43% using the BassUp technology. The battery lasts for up to five hours per bud.
They are powered by Bluetooth 5.0 tech, which is one of the latest iterations of Bluetooth. So you'll get a powerful, low-latency link to your mobile device. Even in busy places, you'll get an unbreakable connection.
Anker's SweatGuard protection provides an IPX7 rating for the earbuds, which means they have a barrier that's watertight. Take the earbuds outside for a run in the rain or to your next workout at the gym. You won't have to worry about them. You can even rinse them off in the sink if they get too grimey.
Slide the earbuds in and twist to activate the GripFit tech that helps them sit securely in your ear. You'll be able to wear the buds even when you're running hard or on a roller coaster or something. Maybe. Probably don't do that. You'll also get four sets of EarWings and EarTips to find the perfect setting.
Need some other audio options? Try Elegiant's true wireless earbuds, which are also on sale and down to just $13. If you don't need to go completely wire-free, you can get Sony's Wi-Xb400 Bluetooth headphones on sale for $38 today.
