Anker's half-price 19000mAh PowerCore+ PD power bank does double duty as a USB-C hub
Staying connected and powered up while on the go gets easier with Anker's PowerCore+ 19000 PD Portable Charger bundle, and now it's more affordable too. B&H has it on sale with half off its retail price for today only, dropping it down to $59.99. That's a match for the lowest we've ever seen it go.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker's PowerCore+ 19000 PD Portable Charger has a secret ability. With a press of a button, it switches to Hub Mode and becomes a high-speed data syncing hub allowing you to connect its USB-C port to your computer so you can utilize its integrated USB ports however you need. It features one 27W USB-C Power Delivery port, a 15W USB PowerIQ 2.0 port, and a 10W USB PowerIQ port, which you can use to power up to three devices all at once. Anker states that its 19000mAh capacity gives it enough capacity to power an iPhone 8 up to six times before needing to be powered up again, while the Samsung Galaxy S9 can be recharged nearly five times.
It's highly-rated at Amazon with a score of 4.4 out of 5 stars on average. Along with the PowerCore+ 19000, it comes with a USB-C to USB-C cable so you can easily power up the power bank anywhere you go. That cable alone would usually set you back around $12.
