Anker's discounted wireless chargers can keep your gear powered up for less
If you're not taking advantage of wireless charging, you've been sorely missing out. Thankfully, Anker is offering a bunch of its Qi charging accessories at some of their best prices ever right now at Amazon. Deals include charging pads from $11 and charging stands from $14 so you can keep your phone topped up sans cable.
The most affordable Qi charger of the bunch is the PowerWave Pad Max at $11.46. This well-rated charger is actually an upgraded version of a model previously released by Anker. It's faster, safer, and more stable. The charging pad can power up your Qi-enabled phone at 5W, 7.5W or 10W depending on what your phone is capable of and comes with a 4-foot Micro-USB cable to get it plugged in. This is the best direct price drop it has ever seen. Alternatively, the PowerPort Wireless 10 is down to $21.50 from its most recent $30 price if you prefer that style with its LED indicators around the edges.
If you want to use a charging stand to prop up your phone while it powers up, you can save on these too. The Anker PowerWave Stand is down to $13.59 which is lower than it has dropped directly before. It can also power up any Qi-enabled device and can output up to 10W for devices that support it. If you want an easy way to ensure your phone's battery remains full, add one of these stands to your desk or nightstand and you can simply rest the phone, in portrait or landscape orientation, and get that battery to 100%.
All of the products linked are backed with 18-month warranties and have many positive customer reviews. It's worth noting that each charger comes with the necessary cable but do not come with a wall adapter. You'll want one with Quick Charge 3.0 to ensure you're getting the fastest possible charge, so it would be wise to pick one up today. If these Anker options aren't for you, be sure to check out our compilation of the best wireless chargers of 2019 for some other options.
