Anker's discounted Powerline II USB-C Cable is designed for a faster charge
Anker's Powerline II USB-C to USB-C Cable is one of the more durable models you can find at Amazon, as it has the strength to last 12 times longer than standard cables with the ability to withstand over 12,000 bends during testing. While it normally sells for up to $14 depending on the color you choose, today you can pick up the black version for only $9.99 when you enter promo code ANKER842 during checkout.
This USB-C to USB-C 2.0 cable supports Power Delivery charging and is suitable for powering everything from smartphones like the latest Samsung Galaxy S10 devices to electronics like the Nintendo Switch and MacBook computers. It measures six feet long so you can use it comfortably without needing to be right beside wherever it's plugged into. The Powerline II is USB-IF certified and Anker even includes a lifetime warranty with its purchase, which is why they've dubbed it "the cable that's yours for life".
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
If you don't have one already, you might want to pick up a USB Wall Adapter with Power Delivery to achieve a faster charge with this cable. Otherwise you might still be stuck at slow charging speeds. Meanwhile, for charging while on the go, our guide to the best power banks under $30 can help you find a portable battery charger worth bringing along on your trip.
At Amazon, more than 250 customers have left reviews for this charging cable resulting in a rating of 4.4 out of 5 stars. Standard shipping is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never tried out Prime before, you can start a free 30-day trial today to become a member and score free two-day shipping, exclusive members-only discounts, access to Prime Video streaming service, and more.
