Anker's $9 car mount works with almost any vehicle
Smartphone car mounts are not a one-size-fits-all product. Depending on your vehicle's vents, your dashboard setup, and the size of your current device, it can be tricky to find a mount that works for you. Anker's universal car mount is a great option that can fit nearly any phone and car, and while it usually costs around $20, today you can drop the price to $8.99 by applying coupon code SGZM658Y during checkout at Amazon. That deal is the best we've shared for this product. Shipping is free on orders over $25 or with Amazon Prime. Non-Prime members can click here for a free 30-day trial to get complimentary shipping on this order.
This vehicle mount is simple to use. Simply pop it onto your car's air vents and you're good to go. As long as you have blade-style vents, the mount will work perfectly. There are three adjustable grips that allow you to ensure the mount is secure.
The viewing angle is adjustable, so whether you are streaming from Spotify or checking out traffic on Waze, you will be able to see your phone's screen with no trouble. The mount is also equipped with a single-hand release system for more convenience compared to other models. It's compatible with most smartphones as well. The foldable feet allow for hands-free access to your phone's charging port and headphone jack. Anker backs your purchase up with an 18-month warranty, and so far, the handful of customer reviews are positive overall.
Now that you can see your phone while you're driving, there are some other accessories you may want to add. This Anker PowerDrive car charger gives you two USB ports for only $6. You can also deck out your dashboard with a Vava Dash Cam at $47 off for a limited time.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
