Anker's 65W PowerPort Atom 3 USB Wall Charger reaches a new low price at over 25% off
Trying to power up multiple devices at once can be pretty tough — or even impossible — without the right tech. The Anker PowerPort Atom 3 is a 65W USB wall charger that's powerful enough to quickly power up to four devices at the same time, even your laptop, and thanks to a sale at Amazon you can pick one up today at its lowest price yet of $39.99. This deal marks the first time it's gone on sale since its release last November. It's normally priced just under $55.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker's PowerPort Atom 3 features a 45W USB-C port that can quickly power up laptops, phones, and even devices like the Nintendo Switch. Its PowerIQ 3.0 technology provides an optimal charge per device so you won't have to worry about overcharging. Meanwhile, there are three USB ports which share a total of 20W.
This is one of Anker's slimmest USB-C chargers. It's small enough to slip into a bag without taking up much space. It also comes with a 5-foot long detachable power cord, as well as an 18-month warranty.
You won't receive any charging cables with this purchase, so you'll want to make sure you have the proper ones to use at home once it arrives. This guide to the best USB-C cables can help you find one to put that 45W USB-C port to good use, while this list of best 3-in-1 USB cables has great picks to use with the standard USB ports, and they're compatible with both Android and iOS devices.
Shipping at Amazon is free on orders totaling $25 or more, though you could receive your order even faster with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, as well as access to the Prime Video streaming service, exclusive members-only discounts, and more.
