Anker's 19200mAh PowerCore+ USB-C portable charger is half off at $60
Anker Powercore
Anker Powercore (Image credit: Amazon)
The Anker PowerCore+ 19200mAh USB-C PD hybrid portable charger with wall charger is down to $59.99 on Amazon. All you have to do is clip the $60 off on-page coupon to get this discount. That's a huge on-page coupon considering the power bank is $120. The charger hasn't dropped in price directly since last October, so if you've been waiting for a deal, this is your chance.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This giant 19200mAh portable charger has enough juice to fully charge a MacBook Pro or recharge your Android smartphone or tablet several times over. Since it has a USB-C port with Power Delivery 27W output you can deliver full-speed charging to a wide variety of compatible devices. There are also two other USB-A ports. You can use those to charge other gear or plug everything in at once and charge three devices simultaneously.
The cool thing about Anker's device is it can actually switch into a Hub Mode. This lets you connect all your accessories to each other, sync data, and more. Essentially going from being just a portable power bank to being an actual hub that lets you communicate between devices.
You'll also get a 30W USB-C Power Delivery wall charger with this purchase, which means you don't have to buy one separately or worry that you've gotten one powerful enough to recharge this huge battery quickly. You'll get the best possible charge here, and Anker backs these both up with an 18-month warranty.
