The Anker Soundcore Life Q20 noise-cancelling headphones have dropped to $40
The Anker Soundcore Life Q20 Bluetooth headphones have fallen to $39.99 at Amazon. These headphones don't drop from their $60 price very often and the current discount matches its steepest ever.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
These headphones have an active noise-cancelling system that helps eliminate ambient noises. Whether that happens to be children screaming, an airplane's engine, or some other obnoxious sound you want to get rid of, you can focus on just your music with the Q20.
You'll also get some Hi-Res Audio with the large, custom-designed 40mm drivers that produce exceptional sound. The high frequencies can reach up to 40 kHz, and the headphones have BassUp technology which can really get those lower frequencies thumping. It actually analyzes the sounds in real time to instantly strengthen the bass output so you can feel it in your chest. Just double press the play button to activate it.
On top of all this, the Anker headphones still last for up to 40 hours. That's with Bluetooth and the hybrid active noise-cancelling activated. The Q20 use Bluetooth 5.0 tech so you won't notice any latency in your Bluetooth streaming, but they do come with a 3.5mm aux cable so you can plug in when you need to. That helps preserve the battery, and you can extend the life of the charge up to 60 hours if you wire in and turn off ANC.
The design of the headphones includes memory foam earcups that will mold around your ears every time you put them on. The headband has rotating joints that will fit to the shape of your head, too. There are four built-in microphones so that some of the mics can be used to cancel out background noises and keep your voice crystal clear when you use the headphones to communicate.
