The Anker Soundcore Liberty Lite Bluetooth 5.0 true wireless earbuds are down to $29.99 at Amazon today thanks to a $10 price drop and an on-page coupon taking a further $20 off. These earbuds normally sell for $60 and rarely drop from that price. Today's deal represents their best price in history.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Soundcore Liberty Lite use graphene drivers for powerful sound. They are smaller and lighter than other true wireless earbuds and have 12 hours of wireless playtime thanks to 3.5 hours from the earbuds and an extra 9 hours from the charging case. They are also rated IPX5 for water-resistance so you can work out with them or get caught in the rain without fear of damaging them.
True wireless earbuds became mainstream last year and there's now tons of choice in the market. That choice can make it difficult to find the exact right set for your needs and budget, though. That's why we put together our list of the best true wireless earbuds to help you decide. The Soundcore Liberty Air are our best budget pick there, though they are more expensive than the Liberty Lite on sale today. That being said, they are $20 off on them too.
Be an expert in 5 minutes
