Anker's Soundcore Infini Bluetooth Soundbar just hit its best price ever
A stunning picture is fine and dandy, but a TV without good built-in speakers is still lacking. If your TV could use a sound upgrade, Anker's Soundcore Infini 2.1-channel Bluetooth Soundbar is a worthy pick, and right now it's $22 off at Amazon when you clip the coupon on its product page. That'll bring it down to $58.99, which is a brand-new low that beats our previous mention by a couple bucks. Shipping is free. You'll get it faster with Amazon Prime.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This 35-inch Bluetooth soundbar features an integrated 2.1 Channel build that's designed to fill your room with surround sound, along with two built-in subwoofers and bassup technology to help it pack an even bigger punch. A dialogue mode is designed to put voices front and center in the mix and utilizes the soundbar's dual tweeters and advanced DSP technology to do so, while its Bluetooth functionality allows you to stream music right from your phone and other compatible devices. It's capable of being wall-mounted too.
At Amazon, more than 100 customers reviewed this soundbar resulting in a rating of 3.7 out of 5 stars. If you're in the market for a soundbar, but you aren't sold on the Soundcore Infini, check out this roundup of the best cheap soundbars available. To add more tech to your home, you might consider these smart home picks under $50 too.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
