Keep the Anker Roav 12800mAh jump starter pro on sale for $66 around for any emergency
The Anker Roav 12800mAh 1000A jump starter pro is down to $65.59 on Amazon thanks to the $20 off on-page coupon and the code ROAVRR44. Without these discounts, the jump starter sells for $110 and rarely drops from that price. Today's deal is one of the best we've ever seen.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Jump Starter Pro can jump start your car up to 20 times on a single charge, and it's compatible with gas engines up to 6.0L or diesel engines up to 4.0L. The copper clamps and other features help keep you safe, too. The 12800mAh battery can also provide an emergency boost of power for your phone or tablet. There is also an integrated LED flashlight that can be used with a special S.O.S. mode. Anker covers it with a 12-month warranty.
