Anker's PowerWave 10 can wirelessly charge two devices simultaneously at 30% off today only
For just one day only, Anker's PowerWave 10 Dual Wireless Charging Pad is on sale at Amazon for $41.99. This 30% discount saves you $18 off its regular price and brings this wireless charger down to the best price we've ever seen it reach.
This deal is part of a larger one-day sale on Anker charging accessories like portable power banks and USB car chargers, which you should check out if you need more help keeping your devices powered up, either at home or on-the-go.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerWave 10 is designed to charge Qi-compatible devices wirelessly and has two charging surfaces built-in so you can power up two phones simultaneously. It's capable of charging Samsung devices at up to 10W while the latest iPhone devices charge at up to 7.5W. All others charge at 5W. You'll be able to charge your phone even through a protective case whether it's rubber or plastic, though it'll have to be less than 5mm thick.
Anker includes an 18-month warranty with this wireless charging pad's purchase, as well as a DC adapter with a 5-foot cable to keep it powered up.
